vafc gains
- efteoh
vafc gains
anyone have opinons/ideas of the gain from a VAFC and a MIVEC converter?
aparently it adjusts the hi and low cam, so seems to do a bit more than a SAFC.
thanks
thanks
- smorison
- The Godfather
- efteoh
well, its going on a fto gpx, and the usual, air filter, im just wondering if its worth getting a vafc and the $100 or so on the converter, or simply a safcII (the 2nd blue screen version)
seeing as the 6a12 are so highly tuned, im debating wether or not electronic mods can squeeze any more kW, or most importantly torque.
- smorison
- The Godfather
- FTO338
I think mikey's is the older type (non-blue screen) but for $50 its still bloody cheap as i've seen them on other forum for $100-150
- GPXXX
- FTO338
From memory there's 3 in Vic member who got VAFC, two of them is MADFTO & WILL. And i can't remember the 3rd Nickname.
- GPXXX
did you mean a MIVEC controller?? if so, i wouldn't bother with it unless you have MAJOR things done to the induction side of things (exhaust + filter + head porting + cams + extractors + ECU).efteoh wrote:well, in short, im trying to decide between a vafc and mivec converter or safcII
But yeah, i think the S-AFC or V-AFC (can't remember which LoL) will give you good returns since it allows flexible adjustments to your fuelling needs...
