Help......... need info
- pinoy_ko
Well i just wanted to know if it would be better to super charge or turbo charge my 95 gpx? also what are the problems i would be facing for either option apart from availability of parts.
- vipfto
turbo easier supercharger has been looked at but not sure if done?
check out bennoz supercharge thread it explains it all in detail
turbo obviously can be done but if your not doing a lot of work yourself be prepared to pay a lot for it
I8A4RE did a lot his own work and it still really does cost a sizable amount
just have aread through the turbo section and you'll getall info you will need![Wink ;)](./images/smilies/icon_wink.gif)
- rock_it
- FTEvolution
Bang for buck, do an engine swap...
The fact that you have a GPX, and that I am still yet to hear from anyone that has had a trouble free tuning session, I think it is the best option.
6A13 is by far the simplest, but a 4G63T from an Evo 4+ would be the shiz, either way you have a dam strong engine to build upon.
I have said it before, but again I say, if I did it all over again, it would be 4G63 all the way...
Smooth and sleepy
Smooth and sleepy
