Indicators stopped working?
Tippin
Post by Tippin »
ok, i pulled out my clock/volt meter surround to respray it as it had scratch marks everywhere. I put it back in and rewired everything, went for a drive later on and found that my indicators are not turning on ...
any ideas on what ive done lol?
I'd be checking fuses ...
kermut
Post by kermut »
hahah i did this when i got my car ages ago..theres two plugs that look the same that fit into your hazards ...look for the other one n swap it should work if it doesnt den ummm your on your own :P
Tippin
Post by Tippin »
ive checked a few fuses and they all seem to be fine
kermut, not sure what you mean mate, ive had a look around the back of the surround and cant find any other plugs that go into the hazards
ive also realised that the low beam on my right headlight has stopped working as well
Thatll be a bulb
    check all fuses under hood too ;) sounds like its earthing out
    Tippin
    Post by Tippin »
    indicators are fixed, its because i didn't plug in the climate control properly :?
    no idea why that would stop the indicators from turning on ... but anywayz
    low beam on RHS headlight still doesn't work, guess that gives me an excuse to get the HIDs 8)
    also managed to crack my centre console again after fixing it and spraying it, :lol: its only one crack though, better than 8 lol
