Car struggles then stalls when started - Stepper Motor???
- koolio1234
Lately, when I turn the key in the ignition to start her up, the engine turns and then all I hear is a churning sound like the engine is struggling to start and the needle shows that its idling really low like 200 - 400 rpm...after struggling for 2 - 3 seconds the engine will just stall. But it will usually start on every second attempt. Once it starts then its no problem at all, no stalling whatsoever. I've also noticed that if the engine was still warm then this doesn't occur. It only occurs when the engine is cold.
One other thing (not sure if this makes a difference) but I haven't driven the fto much in the last 2 weeks and in fact the last time I filled up fuel was over 2 weeks ago.
My question is:
Is this a stepper motor on its way out?
Ive searched around on here and some people have experienced similar symptoms and it turned out to be thee stepper motor.
My question is:
- aza013
- NSW Coordinator
- Valandis91
- koolio1234
Whats happening is exactly what Aza has described ^^^
And what Valandis has described also happens. It churns a bit and when it eventually 'catches' it shoots up to 2500rpm and slowly makes its way down as the engine warms up.
So Im concluding from what you said Ben and what ive heard from other peoples experiences its definitely the starter motor.
Can I change it myself or get a mechanic? How much am i looking at for a new one?
- Valandis91
Does it only do it when its cold? If so, i would say it sounds like 02 sensor, the heater is just about on its way out. Could be leads or coils too but i would start with o2 sensorValandis91 wrote:you misunderstood mine...
when i put mine into drive and start driving when i get up to 2500rpm it hesitates and drops then again at a higher rpm for the first 30 secs or so
- Valandis91
Rotton egg smell is usually your cat converter "shitting" itself and that could cause slight miss fires but i doubt it. I would be guessing that you have two issues
1) Cat dying causing smell
2) Heater on O2 sensor is rooted causing missfire
HTH
HTH
- Valandis91
If it was a cheap cat then yes it could be, especially if your 02 sensor is screwed.
When the 02 sensor is not reading correctly the ecu will run the engine rich to avoid damage. Running rich "CAN" lessen the life of a cat especially on the el cheapo brands.
In saying that one other person has complaining of rotten egg smell but it turn out to be a split cv boot which had flicked grease onto the exhaust.
The FTO only has one 02 sensor (at the front) the one in the rear is a cat temp sensor and doesnt need to be changed.
- Valandis91
nah mate what it is designed to do is throw a warning light if your exhaust temp gets too hot, which in turn would kill your cat quicker. Thats it as far as I know.
- aza013
- NSW Coordinator
ok this is out of the FTO owners manual
the temp sencer will show an overheatproblemwithin the exhaust system.
sShould the light show stop the vehicle for 10 minutes where there is NO dry flammable material such as dry grass etc. (unless you wish to make a clame and get a new FTO)
so yes Simon you have hit it right on
- Valandis91
yeah definitly on the cheap side.
