'limp mode' and Diagnostic codes for Transmission 41 42 43
bluefaze
Post by bluefaze »
Hey Guys,
My car has decided to stay in limp mode eg. Stay in 3rd gear.
Checking the input and output sensor was the first thing I checked (hoping they were just dirty or loosing contract somewhere - no such luck)
I did a diagnostics codes check and the transmission seemsed to be the problem with the netural light flashing 41, 42 and 43, which are the 1st to 3rd gear ratio errors.
Does anyone know are these codes related to the sensors?
If so are new speed sensors easy to find?
Hot_aces
Post by Hot_aces »
Hi, According to the workshop manual which you can download from this site.
Code No 41,42,43 1st - 3rd Gear ratio does not meet the specification.
Probable causes-
Malfunction of Input Shaft Speed Sensor
Malfunction of Output Shaft Speed Sensor
Malfunction of Underdrive Clutch Retainer
Malfunction of Low and reverse Brake System
Malfunction of Direct Planately Carrier
Malfunction of Reduction Brake System
Changing the 2 sensors is probably the best place to start.
Hope you get it sorted and please keep us updated.
Storm
Post by Storm »
As above, the two senors are your best bet. Basically the output speed for a given gear is not corresponding to the input speed for it.
bluefaze
Post by bluefaze »
Thanks guys for taking the time to reply, I will keep you posted.
bluefaze
Post by bluefaze »
Hey Guys,
It's a sad is day! Looks like the transmission is screwed. Anyone have a good GPX, 4speed gear box laying around?
nvr2low
Post by nvr2low »
yh mate i got one coming off my car tommorow man
in perfect condition
Storm
Post by Storm »
bluefaze wrote:Hey Guys,
Thats rough man, what was the problem in the end?
bluefaze
Post by bluefaze »
nvr2low wrote:yh mate i got one coming off my car tommorow man
Hey nvr2low,
So why are you taking your gear box out?
bluefaze
Post by bluefaze »
I am waiting to hear back when the transmission is pulled to bits but hoping it's just the clutches that are gone!
sublime19
Sooty!
Post by sublime19 »
Hey nvr2low,
He's going for a t-t-turbo install!
nvr2low
Post by nvr2low »
hey mate sorry. Yh I am changing my car to twin turbo and changing it 2 a manual also. The gearbox is yours if you need 1 man give me a reasonble price plus postage and it is yours. Send us a pm with your postcode I will try and work out freight.
bluefaze wrote:I am waiting to hear back when the transmission is pulled to bits but hoping it's just the clutches that are gone!
clutch in a auto???
Torque converter..
;) i hope the mechanic aint calling it "the clutches" :lol:
Storm
Post by Storm »
Bennoz wrote:Torque converter..
No codes with a goosed TC, probably the band things that can start to slip in the box, cant remember what they are called but knowing my luck probably something simple like... bands :oops:
