Noise from front
- kosto
Noise from front
Hi i have a noise occuring whenever i hitt the brakes hard, or give it acceleration quickly around a corner, i got told the bushes were worn out but would this make a click sound.
- FTEvolution
Care to elaborate a bit more on the noise?
I get a clunking noise and I can feel it through the floor of the car, turning and accelerating do the same thing. I assumed it was the diff, but I am beginning to think it isn't.
When the car isn't running, and I turn the steering wheel back and forth quickly I get movement and clunking. Think it is the steering arms or similar, best bet is to get it to a mechanic and have them spend a couple of hours going over the suspension and steering system.
If it is either of them it will be dangerous, and needs to be fixed. Myself, my car is parked up until I get more disposable income
Smooth and sleepy
Smooth and sleepy
- vipfto
vipfto wrote:@ kosto C.V joints and most likely bushes
@ FTEvolution for clunking with steering its Tie rod end (balljoint) or in the rack most likely rod end.
for clunk when braking lower control arm bushes are shot and prob droplinks
- FTEvolution
My car is in a workshop as I write this, will keep people updated I guess...
Hope it isn't too expensive, at least it should be cheaper than replacing the gearbox, which is where I was leaning a month or so ago
Smooth and sleepy
Smooth and sleepy
