Hey guys
Just had a look at one of my headlights, there seems to be moisture on the inside on my drivers side headlight.
What's the best way to remove it?
Thanks
Moisture in FTO Headlight?
- Danielk
yep the breather hole works a treat.vipfto wrote:take the bulbs out and leave in sunfor a few hours should do the trick![]()
if it keeps happening may need to drill a breather hole but only as last resort
You can also bake the lights and reseal.
- BorepYano
if you havent done anything it will probably come backDanielk wrote:Ok looks like leaving them alone for a few hours made it go away.
Thanks guys for the suggestions
