6a13tt gearbox and fto box
nvr2low
Post by nvr2low »
hey guys mate is thinking of doin the fto 6a13tt conversion but he wants to know if he buys a half cut can he use the motor and the gearbox and drive shafts. Which would save him a lot of money as his is tip. Would love to know yes or no and if so what you have to do if it will work. Thanks guys
Yes
yip just need to weld up tailshaft as wont be required unless he doin awd conversion too :twisted:
thats exactly way im doing much cheaper to buy half cut and use everything from vr4 as doner motor/box/ecu/ brakes etc etc
nvr2low
Post by nvr2low »
so the drive shafts are the same size and will bolt onto the fto guys. How do you weld up the tail shaft area is it just with a plate
Just use the fto box it bolts straight up
No, you wont be able to use the Legnum manual box. Sure it bolts to the motor but the physical size of the box including the tranfer case & rear tailshaft outlet physically wont fit in a standard FTO engine bay.
RichardB
Post by RichardB »
Bennoz wrote:No, you wont be able to use the Legnum manual box. Sure it bolts to the motor but the physical size of the box including the tranfer case & rear tailshaft outlet physically wont fit in a standard FTO engine bay.
you tried it?
I did.
RichardB
Post by RichardB »
Bennoz wrote:I did.
ok saves me trying.... would the box in its own fit?
what Im thinking is weld up the VCD and replace the gears with a dog set from an EVO and you have a FWD dog box in a Galant VR4 housing :)
I know EVO gearsets fit in the VR4 housing, so its if the VR4 housing will fit in the FTO, as it larger than the standar FTO box isnt it?
