How many kms u can run for Full tank petrol?
Mine just nearly 300kms, Is this normal?
coz my fds said his fto can run 4XXkms.
thanks~
Petrol Usage
- Tingfeng_R
- khunjeng
Re: Petrol Usage
Mine did 550km to the current tank, I just filed up today and checked the Odo.Tingfeng_R wrote:How many kms you can run for Full tank petrol?
thanks~
you should get getting 400+ check your O2 sensor, its probably stuffed.
- Tingfeng_R
Re: Petrol Usage
O2 sensor? i am new, can u explain it? or picture?khunjeng wrote:Mine did 550km to the current tank, I just filed up today and checked the Odo.Tingfeng_R wrote:How many kms you can run for Full tank petrol?
thanks~
thanks.
- khunjeng
Re: Petrol Usage
the first thing to do it download the FTO Manuals :Tingfeng_R wrote:O2 sensor? i am new, can you explain it? or picture?khunjeng wrote:Mine did 550km to the current tank, I just filed up today and checked the Odo.Tingfeng_R wrote:How many kms you can run for Full tank petrol?
thanks~
thanks.
http://www.ftoaustralia.com/modules.php ... load&cid=2
Then use the engine manual and find the section on the 02 sensor, cant remember where it is. It will have a pic
A mechanic can chnage for u pretty easily...
Cheers
- Tingfeng_R
Re: Petrol Usage
thanks a lot mate!khunjeng wrote:the first thing to do it download the FTO Manuals :Tingfeng_R wrote:O2 sensor? i am new, can you explain it? or picture?khunjeng wrote:Mine did 550km to the current tank, I just filed up today and checked the Odo.Tingfeng_R wrote:How many kms you can run for Full tank petrol?
thanks~
thanks.
A mechanic can chnage for you pretty easily...
Cheers
- khunjeng
