jacking up a car
AMACHA
jacking up a car
Post by AMACHA »
can someone tell me where the axel stand points on the fto are(for the front) ie: where to put the stands. Also where is the best place to put hte hydaulic jack when jacking up the front half of your car (i know in the centre) but where on the chasis?
RallyMad
Post by RallyMad »
if you want to jack up the whole front the tow hook is the middle of the front chassis rail. I've been jacking of this for years. It works fine, just make sure you get the jack in a position it won't slip of the hook as the car is jacked up.
The factory jack points (ie. where you should put the stands or where workshops use a hoist one) are under the four corners of the car on the chassis rail under the doors behind the front wheel and in front of the rear wheels. I've never used a stand in these positions as I always get a little freaked out by the noises, maybe someone can confirm this is the correct spot.
I usually put the stands under the rear bush of the lower control arm on the front, seems to work fine but I have noticed some FTO's have a bit sticking out the bottom of this bush and you can't do this.
I am a little unsure of using the factory jacking points for stands but I do think this is the place that you should use. Others that do DIY work, do you always only use this spot?
If you look under there, there is a lip that goes in the middle of the factory scissor jack and on the outside edge there is a little bump that looks like it would fit the cup shape of most axle stands. Can anybody confirm this?
RallyMad wrote:if you want to jack up the whole front the tow hook is the middle of the front chassis rail. I've been jacking of this for years. It works fine, just make sure you get the jack in a position it won't slip of the hook as the car is jacked up.
Yep thats where i do mine from. Infact i have my car sitting up on axle stands under the control arms (where they connect to the body) for about 2 or 3 weeks now
AMACHA
Post by AMACHA »
picture simon pleaseeee
Lawso
Penis Fingers
Post by Lawso »
RallyMad wrote:I've been jacking of this for years. It works fine, just make sure you get the jack in a position it won't slip
HAHAHAHAHAHAHAHAHAHAHAHAHHAHAHAHAHAHA!!!!!!!!!!!!!!!!!!!
i'm sorry
blame the immaturity
:cheeky:
koolio1234
Post by koolio1234 »
i'm sorry
hahaha pissing myself laughing.... :lol: :lol: :lol: :lol: :lol: :lol: :lol:
RallyMad
Post by RallyMad »
i'm sorry
:roll: Don't worry, I won't hold it against you :D
i'm sorry
I hope you don't hold it against him, cause I don't think he swings that way ... :lol:
Yes I am immature also ... :roll:
Lawso
Penis Fingers
Post by Lawso »
EXACTLY WHAT I WANTED TO DO!
turn a normal innocent question thread into disrepute :D
RallyMad
Post by RallyMad »
lawsochap wrote:EXACTLY WHAT I WANTED TO DO!
you should of been here a couple of yrs ago. No thread made it out alive :lol:
Especially if it started with VTEC YO!!!!! VS ....
^^^^ :lol: :lol:
or GPX vs GR
