Ok guys, this is more of question for Ben, but im sure someone else might be able to answer this for me
am i better off getting an air powered (pneumatic) 300nm impact wrench?
or a 240V 260nm electric impact wrench ?
the 240V is significantly cheaper and i also wont need to buy an air compressor
also if i get a pneumatic wrench, what rating of air compressor do i need? how many L/min, psi? hp?
Tools: Pneumatic vs Electric Powered
- jonowong
- vipfto
oki rate air tools big time they are awesome and so useful with so many applications
yes you will need compressor, lines couplings etc
generally home air tools require around 90-120psi
i reccomend belt driven ones not direct feed also as for size a small tank will obviously drain faster. however you can offset this buy having bigger tank attached eg connect to an old car lpg tank will give you plenty of air to use at once it will just take a little longer to fill once you turn it on
- FtoSam
^^^^^ totally agree with all of the above.
Go into any workshop....any real workshop
and they will use air.....theres a reason for that.
- aza013
- NSW Coordinator
- koolio1234
