Quick question about amp wiring
cassio
Post by cassio »
Im in the middle of wiring up my amp and was just wondering if - when you wire the speaker wires up to the amp (i am using new speaker wire) do you run them from the speakers, straight to the amp and not touch the head unit or, do you just splice into the stock wiring that is still connected to the head unit
Thanks Guys
depends what you are trying to achieve
if you only want subs to run off amp then connect them to amp and amp only
if you want speakers to run off amp connect them to amp and amp only
if you want speakers to run off head unit connect them to that only
so in short +12v to amp
rem (connect from head unit to amp)
rca from head unit to amp
earth from amp to good earth
also make sure earth and +12v are same gauge wire what goes in must come out the same
Re: Quick question about amp wiring
cassio wrote:when you wire the speaker wires up to the amp ,do you run them from the speakers to the amp or do you just splice into the stock wiring that is still connected to the head unit
ok i have edit your post to capture the essence of your question :lol:
Wiring speakers is really easy you just have to think of it logically.
What creates the sound? ------- The head unit
What does the amp do? -------- Boost the sound (in laymens terms, i know its a bit more complicated than that)
What lets you hear the sound? --------- The speakers.
What does wire do? --------- Transport the sound
Ok so now we got that out of the way.
Replacing the speaker wire increases quality etc. Now theres no point replacing just a protion of it, you either replace it all or non of it, Cause as soon as the signal hits the factory wire you have lost all the benefit of the new wire........does that make sense?
Im assuming you using the amp for speakers not subs.
So the flow is this
HU --> RCA Cables ----> Amp ---> New Speaker wire ----> Speakers.
The factory wire should be completely discarded
hope that helps
nikhan
Post by nikhan »
What I've done is
1. Wire the amp to the head unit
2. Wire the sub to the head unit
3. Wire the front speakers to the amp.
That is if u have 3 sets of rca output on yeah head unit. A word of caution though, do not wire yeah front speakers to the the amp if yeah speakers are stock because they are gonna blow in 2 secs. That is all.
nikhan wrote:What I've done is
That is if you have 3 sets of rca output on yeah head unit. A word of caution though, do not wire yeah front speakers to the the amp if yeah speakers are stock because they are gonna blow in 2 secs. That is all.
why are you not running sub off amp? thatdoes not makes sense i cant see head unit having enough power to run sub effectivly :?
imo i would run that setup other way round or just have a big enough or another amp to run the whole system properly
nikhan
Post by nikhan »
Oops....my bad. I ran the sub off the amp. Lolz
nikhan wrote:Oops....my bad. I ran the sub off the amp. Lolz
haha thought may of been the case my grandmother could of blown harder than that otherwise lol
cassio
Post by cassio »
Ok, Thanks guys.
I get it now.
Thanks
cassio
Post by cassio »
And also i just wanna know if the silver wire and bronze wire have different polarity - (eg silver + positive, bronze - negative) something like that.
thanks
cassio wrote:And also i just wanna know if the silver wire and bronze wire have different polarity - (eg silver + positive, bronze - negative) something like that.
thanks
ah no just depends which connection you put too
so if silver goes to positve output its positive and bronze neg
or ifbronze goes to pos output its pos and silver is neg just make sure they go to corrosponding inputs on speakers or they will not sound right ;)
cassio
Post by cassio »
Thanks for the help guys.
thats what were here for glad to be of use :)
