Need some help with Greddy Emanage Blue ECU
- koolio1234
Was looking around for one of these nifty little piggyback units and came across this on ebay.
http://cgi.ebay.com.au/GReddy-E-Manage- ... 286.c0.m14
Can you guys have a look at it and let me know if this will go into my FTO because the seller says it wont go into a Mitsubishi in his description. This is unusual because i know some of you guys have used this ecu in your fto's and its been talked about before on here. Is there a special emanage blue for the fto? or is this guy bullshitting?
- koolio1234
Kj, personnally i would save another couple of hundred hundred (
) and go for the emanage ultimate 10kws + depending of what else you have done. It has far better tuning ability than the blue.
- koolio1234
What price?
I doubt that you will get that gain from the blue
Thats not true buddy, i dont have the info (ill copy paste when i get home). It has something to do with being able to add or subtract on fuel and igintion maps
- Delvance
Emanage blue can do ignition and fueling too provided you get the extra harnesses that this one does come with. I think the only thing is the blue can't subtract on fueling but can do plus/subtract on ignition. I've looked it up a bit before and it seems it should be able to do fuel minus too but my garage keeps insisting it doesn't.
The ultimate is better because it has more tuning points, hence more adjustability but the FTO won't need that kind of accuracy unless you've done something serious in your engine bay.
Now the ultimate is kind of worth it over the blue because in addition to being more accurate, the ultimate can run two maps with a simple switch to switch between the two maps. It will remove the japanese 180km/h speed limit AND you can also raise your rev cut, so if you're still making power at cutout, you can raise the revcut a couple of hundred rpms (don't get too greedy on stock internals though!) or you can do it anyways to prevent brushing revcut if you like revving real high.
After saying that though, i would still happily use a blue, even in my V35 (which has a much fussier ecu and engine than 6a12).
- koolio1234
Hmm... what kind of alternatives can you guys suggest to the emanage blue system? Something better or more suited to the FTO maybe? Or is the emanage blue the best way to go for a value for money power gain?
The FTO is no different from most other cars. Only specialist feature it has is Mivec & most piggybacks these days will cope with that. All a piggyback does is change the voltages going into the ECU & 'fools' it into adding more or less fuel etc.koolio1234 wrote:Hmm... what kind of alternatives can you guys suggest to the emanage blue system? Something better or more suited to the FTO maybe? Or is the emanage blue the best way to go for a value for money power gain?
This is the list of different piggyback ECU types I've heard of being used in an FTO:
Perfect Power SMT6 or SMT7
Unichip Type A
Emanage Blue and Ultimate
Haltech Interceptor & Mini Interceptor
Then there's the 'bling' controllers like Apexi SAFCs etc
- koolio1234
- koolio1234
