How to make it shine
Jamie
Post by Jamie »
Does anybody know the best way to polish aluminium. I want to polish the intake and other bits and pieces. Any advice would be a big help.
ok well if its a smooth area that you want to do then half the job is already done :D
all you will need is a tube of autosol metal polish and a tin of brite shine cotton wadding polish.
take some of the brite shine wadding and place some auto sol polish on to it and polish away.
the area will go black as you are polishing do this for about 2 mins and then get a clean cloth and buff off, if not to your likeing then do again.
If its a ruff area then you will need to get your self some wet and dry sand paper starting from a 200 up to a 1500 grit and start sanding :roll: this will take some time well a lot of time :lol:
if you need more info than let me know.
Jamie
Post by Jamie »
Thanks aza. Just one more question. Where did you get the autosol metal polish and the wadding? Would supercheap be worth a go?
Wait up. Make that two questions :lol:
yep supercheap, repco any one of them.
the Brite shine is in a yelloow tin you cant miss it and the autosol metal polish comes in a tin as well as a tube.
best thing to do is ask some one at the shop and let them get it for you saves time :lol:
Taeivon_Rep
Post by Taeivon_Rep »
i just spend a couple of hrs and drinks sanding and polishing these :lol:
48hrs worth of sanding and polishing left..
looking good :D
but just remember dont polish it untill you have finished sanding as it will take you longer to sand back to a smooth surface as the polish filles up the sandpaper.
J
Post by J »
hey T.V are u driving a gr? If so how did u get the actual thing out? Ive started sanding, done a good 10 hours (hand labour, not drilled) and stupid me.... Thought to myself: sh*t it would be so much easier to just take it out.
Ive taken the bolts and screws of but it feels like its glued on or something, it probably is.
If anyone is thinking of doing this. DONT! Its a fkn bitch... Take aza's offer and pay 200bux for him to do it... Would be well worth it
there is a diy by mr wong in diy section how to take it off its easy ;)
dont be so soft :!: its the joys of diy all that hard work eventually pays off and you will feel real good about it once done yourself :D
http://www.ftoaustralia.com/modules.php ... ic&t=12280
vipfto wrote:dont be so soft :!: its the joys of diy all that hard work eventually pays off and you will feel real good about it once done yourself :D
2nd that :D
and also when your finger prints grow back after all the sanding, all the metal dust is gone from the inside of your nose :lol:
you will look at it and say "I DID THAT" :twisted:
J
Post by J »
vipfto wrote:there is a diy by mr wong in diy section how to take it off its easy ;)
So true - but u wouldnt say that if u fked it up hahaha but i agree... The outcome so far has been worth it.
jonowong
Re: How to make it shine
Post by jonowong »
Jamie wrote:Does anybody know the best way to polish aluminium. I want to polish the intake and other bits and pieces. Any advice would be a big help.
get a clean rag...
spit on the manifold..
wipe the manifold...
repeat till chrome like...
koolio1234
Post by koolio1234 »
i'll be doing this but i think that i'll be buying a second manifold, work on that and polish it up so that i can still drive the fto and have minimal downtime.
Jamie
Post by Jamie »
I agree with the down time. I plan on doing this on my x-mas holidays as at the moment I need the car every day to get to work. Thanks for all the help and I will post up some pictures when it is finished.
@ jonowong :lol: Spit and polish!
J
Post by J »
get a clean rag...
Bhaha i attempted to pollish the dirt away before...
koolio1234
spit and polish :lol:
good luck with that jono
