Mechanical mods so far only includes: Apex'i AFC, 2.5" cat-back exhaust & Apex'i pod filter.
With only the cat-back and pod filter, the initial run managed a best of:
105.5kw @ 7649rpm / 295.6nm @ 4776rpm
2nd run with a tuned S-AFC (incl cat-back and filter) netted a healthy:
106.7kw @ 7411rpm / 296.7nm @ 4757rpm.
Note that there is a slight rich mixture for a brief moment when the MIVEC kicks in, but I'm told this is normal for variable-cam'd engines incl Hondas. Car feels much nicer to drive now, revs very smoothly and responsive on the throttle... The torque figures does seem a little 'suss' to me, but hey I'm happy...
I shall scan a copy of my dyno sheet as soon as I can, but I just thought y'all might be interested to know the results for the meantime... WATCH THIS SPACE, hehe...
If y'all are interested in posting the results your dyno run, please provide a scanned copy of your dyno sheets as well (just a way to back-up your claims)... I am also more than happy to host the file for you if required.
p/s: Toni, i had a look at a copy of your 98kw dyno run from the MCCR Dyno Day and yerrr I could see it was pinging quite badly as soon as MIVEC kicked in... might pay to check your ignition timing and/or get it tuned properly...
edit: oh and for the sake of preventing another shitfight, let's not get into the variable dyno debate ok... let us all just take it as it is and learn from 'constructive criticism' rather than pissing off other fellow members...
