timing belt change
- zuihoujueding
timing belt change
Alright, back from ultratune and told that my ride is due for a timing belt change.
he could do a direct replacement for $400 and $800+ which includes the replacing rollers, tensnioners, etc.
so guys, are the prices alright? please tell me if you know someone who can offer better and know more of an fto. i stay in sydney city.
thanks!!!
thanks!!!
do the water pump also.
pump is about $80 and the belt is another $100-$120 depending where you go.
labour would be around the $450 mark
then there's your tappets, if your's is a gpx then you should get them adjusted if you haven't done so, that'll set you back another $250 unless you know how to do it yourself.
- zuihoujueding
if you're doing the timing belt you should do the pump with it otherwise its two lots of labour you have to pay.
pump - cheapest place will be kempys in NZ
timing belt - i got it from an asian auto shop in cabra T987 Gates
i go to maytech in moorebank, if you can make it there, drop by and have a chat to the guy, Mayan.[/url]
- vipfto
Mate make sure when belt is done you do the waterpump, tensioners, ideles and cam seals its easy to do while belt is off if you dont do then you will just have to do it all over again..... as for tappets they can be done any time you dont need to remove timing belt for that
- zuihoujueding
Be careful with that, At that price the kit probably does not have a tensioner in it. Mitsubishi charge $396 for a genuine tensioner (what a rip....)
- Blasphemy
I'm replacing the belt myself at the moment, and most associated parts. Here are the prices I've paid.are the prices alright?
::Auto One - Newtown
$ 90.00 - T987 timing belt
::Camskill UK
$ 60.50 - Waterpump
$188.15 - Hydraulic Tensioner
$ 47.28 - Cambelt Center Idler Pulley
$ 37.82 - Cambelt Tensioner
Luckily I wasn't charged import duty on the camskills parts which has saved me some money. Not sure how much the labour will be. Planning on getting the work done in the coming week.
- zuihoujueding
- zuihoujueding
- zuihoujueding
ya, $400 labour for replacing your own supplied timing belt kit and waterpump.
Alright then....i'll get it done.
Hehe, one mechanic said its an absolute nightmare for this service on a FTO. But i asked if he have done any FTO...NO. Alright, better leave him alone.
Just wondering, directing to sydney people, where do you service your FTO???
http://www.ftoaustralia.com/modules.php ... iming+beltJOeJOe wrote:you sure dayco make kits for GPX? i know they make it for GR but never seen a kit for the GPXzuihoujueding wrote:The brand is Dayco. They have a timing belt kit for fto. you mum can easily source for it.
I still have the kit with me, couldn't find any mechanics who charge me less than $400...
It took me forever but that one's for a GPX
PART No: KTBA087
But then it says this?
FTO Oct 1994 - Oct 1999, 2.0L, V6, 24V, DOHC, MPFI, GR, EngCode: 6A12, Import
- zuihoujueding
