brakes conversion
unknownperson
brakes conversion
Post by unknownperson »
i am converting my 2000 ce lancer to fto brakes, i almost have everything i need, all i am missing is
rear caliper mounting brackets
hand brake cables,
does anyone know anywhere i can get these from, pm me or leave a post thanks
jonowong
Post by jonowong »
dstocks!
Are the rears not identical to CE lancer anyway?
The hubs are 4 stud on a lancer thou.
unknownperson
i have everything i need apart from the mounting brackets and hand brake cables, that means hubs discs, calipers etc yes it might not be an exact fit, obviously, they are two different cars, so yes there will have to be some customising done, what else is new. the only thing i have ever found that i have put on this car that didnt need customising was the mitsu remote central locking that was designed for the car!
what do you mean? the brakes are the same apart from stud pattern on hubs why would you want to change to something you already have?
unknownperson
brakes are totally different on the lancer the discs on the front are absolutely tiny, and only single piston calipers, where the back brakes are only drum brakes
Yeah, have a set of handbrake cables and probably the other bits you want too. Send me a PM and well work out the details
    ah didnt realise you must have glxi model?
    The GR FTO brakes are only single piston callipers to but think disc is same size as GPX however they all have disc rears.......
    I got to ask why the brakes? what are you doing to the motor for required upgrade?
    unknownperson
    droping in a 6A12 mivec, currently rebuilding with forged internals, some head work and finally turbo
    Sounds interesting let us know how you get on with turboing the mivec will be interesting if succesful and reliable
    vipfto wrote:The GR FTO brakes are only single piston callipers to but think disc is same size as GPX
    GR is 256mm disc, GPX is 276mm ;)
    haha my bad :lol:
    thought seemed strange gpx being same size disc :lol:
    unknownperson
    so is anyone actually going to answer my original question?
    where can i find these parts?
    unknownperson wrote:so is anyone actually going to answer my original question?
    dstocks wrote:Yeah, have a set of handbrake cables and probably the other bits you want too. Send me a PM and well work out the details
