Rough running and smoky exhaust fuel smell
Ok guys come across a prob with mates FTO
His car is idling wee bit rough but have changed all plugs leads etc and is definatly running on all 6
The exhaust note is now deeper than usual and is blowing a whitish smoke from exhaust (And no its not head gasket!!!!) which also has a fuel smell to it It wont be piston rings as no blue colour or oil smell
When he puts in gear whole car basically shakes with foot on brake but does drive smoother when going however is a loss of power
Will check ECU codes for him tonight but I may think he has a sticking lifter or valve seat buggered? as it is obviously not burning all fuel therefore the valve is not openeing to let air into chamber
Anyone else have any ideas?
White smoke is usually burnt coolant... I know you dont think its a head gasket, but how did you check that? By looking at the oil? Because the gasket can blow directly between a water gallery & the cylinder... The only thing you'd notice would be a drop in the water level - which can vary from a very slow drop, to a very fast drop.
Checked both oil and coolant and then we pressure tested coolant system its all good
Sorry I should explain myself better the smokey colour is more clear than white but very very distinct fuel smell?? hence why I think valve or lifter
Ah, ok. Pressure tested the cylinders?
Yip front three but not the rear did remove manifold over day and plugs an noticed driver side rear cylinder ( cant remember number) had strong fuel smell and residue on plug and looked like small bit of fuel/oil residue on top of piston but hard to be sure without removing head....... and very stong fuel smell and visible vapours in manifold
Could be sticky injector...
Just that I've never heard of a valve jamming of rocker arm breaking in an FTO..
neither have I i'll also run a cleaner through it and take rocker cover off and check the lifters aswell as ECU check will let you know results
Sugar
Post by Sugar »
i had simalar problems with my first engine swap.
checked vacuum hoses? more so the 1 on the back of the intake manifold.
exhaust note is deeper?(ie nothing like an fto?) thats what ive got at the moment. bringing up a detonation sensor when i checked codes.
and its very sluggy. down low.. but 1ce its over 3-4k its fine.
just gotta find sombody to do it :|
dB wrote:i had simalar problems with my first engine swap.
Acutally sounds similar very deep sound and slow then once revs are up seems to be better however still not as fast as normal i'll be doing ecu check tonight detonation sensor could certainly be possible I hope so for his sake I dont really have time to pull head off etc 8O all vaccum hoses are connected :D
Sugar
Post by Sugar »
yep sounds almost exactly like my problem.. fuel smell is really really bad when you first start her up?
wont be easy to fix if it is your detonation sensor.. smack in the center of the v..
thats why ive left it so long lol
dB wrote:yep sounds almost exactly like my problem.. fuel smell is really really bad when you first start her up?
Yeah... you didnt give me enough beer to dig that far in to your motor :lol: Intake off for plugs was enough!
Easy job mate if its that problem i'll even post up a DIY for you, just need to remove intake manifold, fuel rail etc there is bugger all there to get to it takes me maybe 45 mins to take apart just need to be carefull not to drop any nuts down there or break the gaskets :D
Sugar
Post by Sugar »
if you could do a diy that would be sensational..
failing that ill just buy ben a few more beers lol
Sugar
Post by Sugar »
so how much is enough sir?
hummm ben could you caps me the part number?
Would we be safe in thinking it could also be called a "ignition failure sensor"?
Sugar
Post by Sugar »
i duno lol. your the brains and brawn i just bring the hammer.
i thought it was more of a knock sensor?
cjam
Post by cjam »
got my money on an injector cause ive got the same problem. it happened once before, thrashing the car for a few mins fixed it all good. but its the same again now so im going to get my efi guys to look into it over the next few days.
Did ECU check last night and NO error codes :?
I still think valve or lifter but dont have time to pull head off for him so he will have to take to shop :cry:
Too many variables! First tihngs that came to my mind was blocked cat or leaky head!
exaxtly what i thought until I started to eliminate probs but for one there is no cat and two pressure tested for head gasket but like I said not my prob at mo and dont have time to look any deeper for him
