My Poor Fto
DanXbix
My Poor Fto
Post by DanXbix »
My poor FTO GPX has a few issues atm first off the battery is going flat within a week after full charge i know most likely the alternator. When reving car not in gear the battery light comes of at arround 4000rpm and off after & before that. The Next problem is my clutch is sliping i like in 2nd 3rd 4th & 5th, In 3rd & 4th it sometimes takes arround 1000rpm to catch.
1. Will i Need Alternator
2. Will i Need New Clutch
3. Price's & brand i should use for clutch
4. approx cost
Thanks for your help
yes you will need both best to pm d-stocks he will put you in right direction for part costs and depends how handy you are with spanners to how much labour it will cost you :D
The first problem is definitely your alternator, I had the same problems a month ago.
Breza
Post by Breza »
DanXbix
My alternator went just a few months before I sold my FTO.
Autocraft replaced it with a new one for around $350.
May be better getting a new one in preference to a second hand one depending on price.
Cheers
Chris
