suspension troubles
nvr2low
suspension troubles
Post by nvr2low »
hey guys my car creaks now everytym i go ova a pump or up a hill and some times when i brake or take off fast does this mean my droplinks are shot
speedcrushdemon
Post by speedcrushdemon »
could be... also have a look at the antirollbar bushes... i used to have the same problem and finally got this.
try 'climbing' over a hump (for instance a small roundabout)... making different ride height between left and right... if u can hear the noises, then it could be the ARB bushes :)
by the way i did replace new droplinks all round at the same time.
<a href="http://s6.photobucket.com/albums/y217/jacobchan83/FTO/?action=view&current=15362_206082000019_607980019_447264.jpg" target="_blank"><img src="http://i6.photobucket.com/albums/y217/jacobchan83/FTO/15362_206082000019_607980019_447264.jpg" borde
As above most likely droplinks or ARB bushes
another thing is the top strut hats when worn they can make clunking sounds and affect handling too
I replaced mine not too long ago had same issue as you but also did droplinks etc also
nvr2low
Post by nvr2low »
ok guys I replaced the droplinks and the creeking noise still happens. The car also creeked when I let the car down off the car jack it creeks and the rear makes a clunky noise when I go over a sharp bump. So can anybody please help
nikhan
Post by nikhan »
Try lookin at ypur engine mounts for the clunk noises...if not might be the brushes
nvr2low
Post by nvr2low »
nah the clunky noise is only from the rear of the car it is like the suspension is goin up then coming down and making the noise but when i jack the car down their is creekying noises coming from the front and the back when the wheels touch the ground like it is taking the weight and when i go down my drive way it creeks. sometimes it creeks when i turn
xSlurpee
Post by xSlurpee »
wheel hubs or bearings maybe? when i had this noise and creak problem it was my hubs and cv joint
replace rear droplinks and maybe shocks creaking noise when lowereing car down is normal :lol:
$50 on swaybar bushes!
topao
Post by topao »
Bennoz wrote:$50 on swaybar bushes!
Just dont be an Idiot like me and select the wrong ones and end up having to buy a second lot
nvr2low
Post by nvr2low »
Ok bennoz which ones do I have to buy I got a 95 gpx
Gen Mitsi part is MR197005.
Possibly cheaper thou to go for poly bushes from Fulcrum (3892 9000) Part number is SPF1344.
Fulcrum will post out to you as well.
nvr2low
Post by nvr2low »
hey bennoz is it the same part number for both rear and front as i may aswell change all of them. Do they come in a Pair, u buy them as a set to be able to replace both on the front and both on the rear or u gotta buy them individually
nvr2low
Post by nvr2low »
hey bennoz is it the same part number for both rear and front as i may aswell change all of them. Do they come in a Pair, u buy them as a set to be able to replace both on the front and both on the rear or u gotta buy them individually. what state is fulcrum in man need the state phone code
xSlurpee
Post by xSlurpee »
you could've edited your post instead of double posting! (to be honest i just want a higher post count) :lol: :lol:
No, the rears are different. They are an 18mm bush. If you go through the suspension thread stickied in the top of the Technical / Performance section, you'll find every bush part number in the car. Its about page 4 or 5 of the thread I think...
nvr2low
Post by nvr2low »
ok will do thanks guys
nvr2low
Post by nvr2low »
ok i was looking around are these the correct bushes i have to order for the front and rear sway bars are these also knowen as anti roll bar bushes.
http://www.camskill.co.uk/products.php? ... b0s10p7731
http://www.camskill.co.uk/products.php? ... b0s10p7732
nvr2low
Post by nvr2low »
Hey guys are these the right bushes I need to buy
You ignoring my advice again mate? :lol:
spf1344 - 16k for front sway bar bushes
spf2004 - 18k for rear sway bar bushes
Buy from Fulcrum (number listed above) - they will be cheaper & better quality being polyurethane.
