Removing FTO Clutch
- FtoSam
Removing FTO Clutch
Okay... I need to take my gearbox out...
two options:
1) Do it at a mates place (He has room to leave the car there for as long as needed and all the tools including jacks, engine hoist, etc)
2) do it in the service dept at work and pay off the manager with lots of beer... But can only work on it on days off (once a fortnight)
How hard is it to get out the FTO box without hoisting it?
Is it just going to be easier to get the engine AND box out at once?? It would give me a good excuse to change engine mounts, do the tappets and lifters, and fit all my guage senders... not to mention a bit of chroming...
Thoughts?
two options:
Thoughts?
- AMACHA
Service dept for sure, it has to come out underneath. You need to pull the lower cross member out anyway, so you do the mounts then as they bolt to it.
Might be worth your while getting another pressure plate from a wrecker & having the springs on it beefed up before hand. Then you could do the whole job in a day - seeing as you're not replacing the clutch plate itself, there's no need to machine the flywheel mating face. All you'll need is a clutch plate aligning tool for when you reassemble.
Also, if you're doing tappets - dont forget in the non mivec motor, they aint adjustable, you just need 24 replacements from Kempys.
- FtoSam
- vipfto
we did all gearbox removal on the ground. Undo everyhting you can from the top jack the car up as high as you can get it, place under to axle stands, undo everthing at the bottom, use jack to take weight of gearbox. then lower jack easy as
- vipfto
how does it hurt your back??? All our mechanics did it on the ground and we had 4 hoists.
- vipfto
Just a pain in arse getting under car on back on hard floors, especially when car is so low to ground i'm sure most people here dont have access to most of the equipment we are used to in workshops like creepers etc
Why did they not use hoists? makes life soooo much easier
What are you, the guy who likes to do things the hard way??I8A4RE wrote:how does it hurt your back??? All our mechanics did it on the ground and we had 4 hoists.
I've pulled a few boxes out & I wouldn't touch it it with a 10 foot pole if there was no hoist. In fact Im pulling mine out again next weekend to fit the new diff
No i just perfer to be laying on my back
- FtoSam
LOL
HEy simon... do you a deal... you come up to brisbane one sunday and help me remove the engine and box, and i'll give you my pipework for a week to get duplicates made up....
Should halve the cost of getting yours made....
Not looking to do this for a while now as my tax return was far far less than anticipated...
Hmmmm, sounds promising through in some beer and you got your self a deal
. Why are you removing engine as well
