speedo has gone on holiday
hi guys
my speedo has stopped working
the rest of the gauges are fine
its also not adding km/s i supose they go hand in hand
any ideas?
any ideas?
- aza013
- NSW Coordinator
- Grue
I will probably have a gauge lying around somewhere if you get desperate mate
I think it would be more like the connection at the gearbox but im not family with the manual g/box
well everything looks to be in order on the box.
just fiddled with stuff lol!
upon further inspection
in the drivers wheel arch.. i took out the plastic liner as it was rubbing badly. i looked up and there are a few wires that have had the plastic coating stripped and bare wires are showing..
could be a reason?
could be a reason?
i doubt it, i dont think the wires travel through the wheel arch but i could be wrong, mate if i didnt have so much on plate at the moment i would try and have a look sorry. The only thing i can suggest is check out the wiring manual and try and see what the wire colours are.
oh ben, you whore
- Supplanter
Okie dokie
checked the gearbox.. all seems to be in order
still a bit concearned about open wires in drivers wheel arch.. so i taped them for now..
may have to get a new cluster (hi dwayne)
but just out of curiosity can you make the speedo needle move with the gauges off the car? connect power to any of it?
- FtoSam
- rock_it
- rock_it
