Moderators: IMC , Club Staff
Valandis91
Posts: 1169 jedwabna poszewka promocja
Post
by Valandis91 » Thu Jul 03, 2008 11:45 am
just wondering whether the orange with white stripe wire behind the centre console is the one that goes to the car light control switch???
cos the head unit i bought has the orange and white stripe wire that has to connect to it but just double checking whether the one in the centre console is the same...
cheers
Posts: 4154 Joined: Mon Oct 29, 2007 5:00 pm
Post
by vipfto » Thu Jul 03, 2008 1:03 pm
Could be but dont assume that because its same colour it should match up
READ WIRING DIAGRAM FIRST and if that fails get out voltmeter or even test light to check them all first
Valandis91
Posts: 1169 Joined: Mon Mar 17, 2008 5:00 pm
Post
by Valandis91 » Thu Jul 03, 2008 1:27 pm
i tried that but i couldnt find it or im not reading it properly
Post
by vipfto » Thu Jul 03, 2008 1:58 pm
check diagrams from previous threads they are here somewhere
OR just use voltmeter etc when you turn on lights it should tell if that it is light wire
