Getting rid of clue in the roof
- AMACHA
Nowi v been reading the rust threads and im a bit stressed out.just wondering i havea 95 gpx and it was importedi n the ocuntary in 1998 by the previous owner.And since 98 it has always been garaged so neverleft out in the rain.Is rust still a big problem for me i cant see any spots on teh roof yet...should i try and get rid of the glue now or?oh and does the glue that you remove need to be replaced with anything?
Relax mate, they changed the glue in 96 or 97 (cant remember which). Youre safe. You dont need to do any of the stuff I put in the guide because the glue in your car does not collect moisture.
Sorry, I misread your post
. You said 'since 98', and I dont know why, but I read that as a 98 model. In that case yours will have the potential to develop rust and if I were you, id remove the roof lining and get rid of the glue before that occurs. Coathanger does a good job. The guide I posted shows you what you need to do. Takes about an hour to carry out.
- AMACHA
thats ok mate then do i need to get where i drill re welded mate?how much would this cost?also since im tkaing out the glue do i need to put something there instead like anotehr type of glue?dstocks wrote:Sorry, I misread your post. You said 'since 98', and I dont know why, but I read that as a 98 model. In that case yours will have the potential to develop rust and if I were you, id remove the roof lining and get rid of the glue before that occurs. Coathanger does a good job. The guide I posted shows you what you need to do. Takes about an hour to carry out.
If you dont have a sunroof you dont need to drill anything out. If you do have a sunroof, there is a separate subframe around the sunroof (under the lining) that has glue separating it from the roof skin and if there are rust spots in the roof there, the subframe has to be removed to fix the rust problem properly. This involves drilling out the spot-welds. Hopefully, you dont have a sunroof and can ignore this bit. Plus, if you dont have rust spots atm, I wouldnt get the subframe taken out anyway. Just remove the glue and hit the exposed metal with a bit of rust neutraliser after having removed any loose rust.
The glue is used to separate the roof skin from the subframe underneath. In the case of a car without a sunroof, all that is required is to remove the glue and neutralise whatever rust you find. I never bothered replacing the glue. There is a 5mm gap between the bits of metal, so theyll never touch and rattle
- AMACHA
Oh beautiful then dstocks ill get on it i dont have a sunroof so itake it all i need to do is take ioff the lining get the coat hanger out remove all the glue from the front and the back sections and look for any rust already present use a drill with some wire on it to get rid of the flake bits and hit it with the rust converter then done is that pretty much it mate?
yep. But only use the drill with a wire brush if the rust is significant. The wire brush attachment does a really good job, but you have to be really careful with that as it can catch and put a dent in your roof if you arent careful. If there is just a bit of surface rust, scrape any loose bits off with something like a metal paint scraper and neutralise with rust converter and then maybe hit with a bit of undercoat after it has dried. In your case the glue you will have to remove will be about 10cm from the top of the front and rear windscreens.
- col2560
i just did mine yesterday, i used a hacksaw blade to cut/scrape out the old glue. use with teeth pointing back towards you. only took about 1/2 hr to get it all out. then i painted it with a product called "Penetrol" its a penetrating oil/sealer. make sure you use a small artist's brush or something similar that will reach into the small gap.
Did you have rust when you got the lining off Colin?
It wont until it breaks through from underneath. Trust me its worth removing the glue.
- MissxFTO
- col2560
- maggsy
wince!. Do you get wet when it rains.
- maggsy
