Advice from RPW
- Jamie
Advice from RPW
Hi guys.
Just wanted to get some opinions on some recent advice I recieved from Racing Performance Works.
I have a 1997 Gr FTO and want a mild performance upgrade. I asked RPW about lifting the performance of the 6A12 and asked if a rebuild would be necessary as the car has travelled 130 000kms. The only requirement I asked of them is to keep the engine naturally aspirated. This was my reply.
"To be honest you dont need to touch the engine internally, I would just suggest doing good mods around the outside and regular 5000km oil changes and the engine will handle anything you can throw at it.
I would recomend mods wise to do extractors, exhuast, intake, piggy back ecu, intake manifold, throttle body, and a FPR unit with a fuel pump upgrade. This package will retain driveability, economy but hefty HP improvement and make it accelerate harder."
I have my doubts about the FPR and the fuel pump upgrade without changing the injector size however I may be wrong.
Opinons please......
No that sounds about spot on. The standard injectors only run about 60% so upgrading fuel pump and FPR will give it a good increase especially if you install a piggyback. I cant recommend emanage enough, great product.
- aza013
- NSW Coordinator
yeah between 25 and 35 extra kw would be round about where id be guessing
You got a FPR though, dont you?Bennoz wrote:Yeah scrap the fuel mods. I run a 160kws with nitrous on & I've never needed to upgrade a pump or injector.
- Jamie
Thanks for everybodys help. Yeah I was leaning towards the fuel mods not really being necessary.
In regards to the fuel pressure regulator, I was under the impression that it was only really requied on force fed engines. Is this correct?
The cost doesnt worry me too much as extracting HP from naturally aspirated engines is always a difficult and expensive task to under take. I understood that when I choose to buy the FTO. ( However I believe there is a difference betwen spending my hard earned and wasting it. LOL)
A 30-35kW gain should be fairly noticible and hopefully give a little more low down tourqe which in my opinion is much needed.
One last thing. In my response from RPW they stated replacing/modifing the intake manifold. A search of their website did not reveal any aftermarket intake manifolds. Does anybody know of one or where they may be purchased?
No fpr increases fuel. more fuel = more power.
As for intake im pretty sure hes refering to boring out the intake plenium and throttle body
- khunjeng
hi mate
your best bet is to perform the following mods - in this order
Step 1:Getting Ready
Change all oils
Change Oil, Air and Fuel filter
Change Plug and if you feel like it, new plug leads
Chnage and Check all Brakes, suspension
Get tappets adjusted
Step 2: Engine Mods
CAI Stage 1- upgrade intake pipe and pod with shield or just K&N hi-flow panel filter
CAI Stage 2- Better and less restricted feed to the Pod or Airbox form the front
Exhaust Stage 1- High Flow Cat and NewMuffler
Exhaust Stage 2-Extractors and downpipes from RPW
ECU - Install Emange Blue + Tune
Step 3: Suspension & Tire
Upgrade shocks and springs
Make sure u have good tires
Replace all old and busted bits - droplinks and bushes
Upgrade swaybars
Then your car will be nice.....I would not worry with all the other mods mentioned until these have been done first.
Change all oils
Step 2: Engine Mods
Upgrade swaybars
- Mitsiman
If I recall, when you contacted us you advised you were going to be racing the vehicle as well as street duties.
With that in mind though
The FPR unit I recommend as it allows you to effectivly increase the accelerator pump value on the vehicle which cannot be done with a piggy back ecu.
The piggy back will allow you to retune the fuel/ignition curves for sure.
Once you do some exhaust mods especially the extractors this will lean out the fuel curve on acceleration and induce a flat spot, especially when combined with air intake and most especially if you go for an upgraded manifold and 65mm throttle body package. This is where the FPR unit becomes necessary.
Fuel pump only because you are racing, and it is something that is the heart of your fuel supply.
Also especially if your racing, the thermo block gasket kits to reduce heat soak into the intake manifold. These are mods that have been out there for the FTO owners for at least over 5 years so nothing new here
- Jamie
Thanks for the information. The fuel pressure regulator makes a lot more sense to me now.
Now that you mention it, I have noticed a flat spot in acceleration at around 2500-4000rpm. I installed a custom cold air inducton into the standard airbox and a Jasma cat back exhaust. Could that be related?
If this is only going to get worse I think the FPR may be one of the first mods I perform.
Yeah the FTO will be seeing track time hopefully begining of next year. The missus and I bought a 2008 Jeep Wrangler so I will still have wheels while I take the FTO off the road. Everything going to plan the work should be done at the end of year.
The emanage will also get rid of that flot spot. Mine has some really nide excelleration now especially when it starts to get into mid range
