fuel pressure regulator question
- tintin
do i need 1 of these ? would it help in any way?
coilovers!! gaurenteed to make boobs bounce
Through my research i would say no, not really unless you plan on forced induction. A fuel pressure regulator is designed to give added pressure to the fuel system which in turns forces more fuel out of the injectors. This is important in forced induction becuase the engine needs to run richer as to not cause detonation or the engine will blow. However not so important with n/a cars. I could be wrong though thats just what i have read
- Shahrez
it's also basically to maintain a constant fuel pressure above the intake manifold temperature.
you don't necessarily have to have forced induction in order to put one in, forced induction requires a different regulator anyways. Rising rate regulators, thats what they are, different to the typical regulator.
But then again unless you have larger aftermarket injectors (on your N/A car) then not much point in getting one!
No you shouldnt cause the factory ones only operate at about 60% anyway
- aza013
- NSW Coordinator
- aza013
- NSW Coordinator
- aza013
- NSW Coordinator
- aza013
- NSW Coordinator
Anyone know of a cheap fuel pressure gauge.... i really only need one for installation of the FPR, it will not be mounted in the cabin
- mr-charisma
Make sure you download Firefox 3 on their download day tooaza013 wrote:thanks for that Ben I will down load it asap
http://www.spreadfirefox.com/en-US/worldrecord/
