Hey guys, we were poking around the fuse box yesterday and found that mine has no cover on it. So we do not know what is what. We replaced the 3rd one from the left on the bottom row because it was broken. It was rated 15. Does anyone know what this is for? Also the gear lights on the dash are flickering and some times dont work. Does anyone know how to fix this without pulling the whole thing apart, which I don't know how to do anyway.
I will post pics of the air intake as soon as i figure out how.
Thanks guys. Anna.
Fuse Box
Sounds like an electrical fault of some kind would cause the flickering lights (broken wire or bad commection. Could be as easy as reseating your instrument cluster (5 minutes work) or could be something harder to track down.
I have a spare fuse box cover if that helps, but it is in Japanese (as are they all). Here is the translation:
http://www.completefto.com.au/CompleteFTO.asp?aid=447
Hope that helps
cheers
Hope that helps
cheers
Complete FTO (http://www.completefto.com.au/completefto.asp) ![Image](http://www.completefto.com.au/assets/contentitems/sig4.jpg)
