RRFPR
RRFPR
Found this one, but a bit confused. I thought that wanted a 1.7:1 where as this is a 1:1.7. Does this make a difference or can it just be said anyway round. Any help please.
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 3DWatching
Ben is that you have.
Thats the one. 1.7:1 or 1:1.7 same thing. It just means as the fuel pressure is increased by 1.7psi to every 1psi of air going in.
Sweet, so i can install before the turbo cant I. i mean its not going to affect my tunning in a negative way is it?
FtoSam
Post by FtoSam »
if anything it should give more power.,..
Make sure its setup right though... My first mechanic put it on the intake line... lol
It wont give you more power on a stock setup, all it will do it increase the fuel back pressure in the line - no more fuel will be pushed thru the injectors, it'll just ensure you dont suck the rails dry when you nail it. You can install it without the turbo, I've been running one for years. Just make sure you get the pressure set on it properly. I think mine is on 45psi.
So is there a screw or something to set the pressure, and i suppose you need a gauge to set it?
Yeah there's a dome nut & adjuster thread. You can adjust it by eye as it comes with a gauge that sit ontop of it permenantly, just need to do it without the manifold pressure line attached from memory.
Sweet cheers mate, i will purchase this now. Oh and it goes after the factory FPR regulator doesnt it? Any pics of mounting position, god damm i ask a lot :lol:
No, the factory FPR is removed altogether.
To be honest I wouldnt buy that one in the link. It doesnt look likes it comes with the gauge & it is specified for a Ford Escort. Keep your eye's peeled for a Mitsubishi specific one. The only difference is really the fuel rail adaptor to suit Mitsi rails - otherwsie you'll end up having to make something up - as the standard FPR is removed from the end of the rail to start with.
Also just found the correct setting for them:
2.78 bar with vacuum connected and at idle (40.32psi)
unknownperson
Post by unknownperson »
i just bought a cheap $80 off ebay, no brand name or anything its a universal one that came with a coupple of different mounting plates and came with a guage, havnt had a hint of trouble from it, although its not a rising fpr i has made a difference eliminating flat spots in the rev range, im going to swap it over to my 6a12 engine when i put it in my car
heres the link to one
http://cgi.ebay.com.au/Adjustable-Fuel- ... dZViewItem
Cheers mate, i really want a rising rate though as i am going to be turbo'ing my car and from what i have read its the best for it.
So if anyone sees a rising rate with fuel gauge please let me know
Its a pressure gauge they come with :lol:
