Page 1 of 2
i think........i have to higher up my front a bit....
Posted: Sat May 03, 2008 11:52 pm
by Criss
it some how scratch the tires when people are inside the car
i hate those "errrrrrrrrr" sound form the front
Posted: Sun May 04, 2008 12:33 am
by I8A4RE
it some how what??
If its what i think your saying its most probably the droplinks. Mine make a bit of noise since lowering the car
Posted: Sun May 04, 2008 12:55 am
by Criss
I8A4RE wrote:it some how what??
nono, the tires just scratch the car......i'm sorry about the typing mistake again and again...
Posted: Sun May 04, 2008 1:00 am
by I8A4RE
What size wheels and tires you got on and how low is it
Posted: Sun May 04, 2008 1:03 am
by Criss
I8A4RE wrote:What size wheels and tires you got on and how low is it
it's a 225/40 R18
i can out 2 finger between the car and the tires
you get what i mean?
Posted: Sun May 04, 2008 1:05 am
by mr-charisma
hmm...
Could be that the wrong profile of tyre is fitted for the wheels you've got ..
Could be that your suspension / struts are worn if it happens going over bumps or cornering sharply..
Could possibly be worn springs, might need replacing if the spring rates are buggered.
Check under your wheel arches to see if the wheels are rubbing on the plastic guard .. if the plastic guards on wheels arches are loose, cable tie them back up if they're hanging too low hitting your tyres..
Also, you can do a basic suspension check by pushing down on each of the struts& if the suspension keeps bouncing / doesn't stay firm when you let off it could be faulty suspension
Take it in to Pedders for a $14 check if you think there might be probs..
Posted: Sun May 04, 2008 1:14 am
by Criss
mr-charisma wrote:
those suspension are new as i remember
it scratch while i turn the steering reali reali hard
Posted: Sun May 04, 2008 1:26 am
by I8A4RE
Really you should have 35 profile for those rims. I have 225/35/18 and i get no rubbing at all. But like mr c said it could be everything that he said as well. It also could be the offset of the rim
In saying that i just checked my car and i can get 1 finger in so mine is sitting lower than yours. So im guessing its the offset of rim or multiple factors
Posted: Sun May 04, 2008 1:33 am
by Criss
I8A4RE wrote:s
so i hv to change for new tires???
tats a very bad news for me
Posted: Sun May 04, 2008 7:45 am
by REDDERthanyours
criss - are you asian?
Posted: Sun May 04, 2008 9:16 am
by bushido
Very high possibility.
Posted: Sun May 04, 2008 9:37 am
by I8A4RE
Criss wrote:I8A4RE wrote:s
Nah just jack youir car up get a big hammer and smash the area where is it is rubbing
No dont i was kidding
Posted: Sun May 04, 2008 10:31 am
by manofwood
he probably would have if you didnt say the last bit
Posted: Sun May 04, 2008 1:08 pm
by Criss
manofwood wrote:he probably would have if you didnt say the last bit
i wont
Posted: Sun May 04, 2008 1:09 pm
by Criss
REDDERthanyours wrote:criss - are you asian?
because of.....chinese english?
trying to improve it, but it's hard
Posted: Sun May 04, 2008 3:35 pm
by I8A4RE
Criss wrote:REDDERthanyours wrote:criss - are you asian?
its alright mate we will get you through
Posted: Sun May 04, 2008 3:57 pm
by mr-charisma
Don't worry about it mate, could understand the gist of it - I8A4RE is sometimes harder to understand, and english is his first language
If you don't mind me pointing it out (I find that every little bit helps learning another language);
Instead of saying "I think I have to
higher up the front a bit
it should be "I think I have to
raise the front a bit[/b]
Anyway, I8A4RE wasn't exactly wrong about getting under there with a hammer .. depending on where it is rubbing against, it could work .. but you would just have to make sure that what you'd be hitting with the hammer is not important..
Posted: Sun May 04, 2008 6:59 pm
by speedcrushdemon
Don't worry mate you'll be alright. I'm asian too. I reckon you're from malaysia am i rite?
Anyway I'm having scrubbing problem too...
Posted: Sun May 04, 2008 7:40 pm
by I8A4RE
EDIT:
Thats cause im usually drunk
Posted: Sun May 04, 2008 10:46 pm
by sublime19
I'm pretty sure the problem is the 225/40, as somebody said before 35 would be right.
