Brake upgrade
- FtoSam
Brake upgrade
Im looking at two different Used brakes....
Both are in great condition...
They are:
Item: Front pair genuine PORSCHE 6-spot brakes, including PORSCHE brakepads (99% unused) and PORSCHE 353mmx34mm crossdrilled discs.
Item Condition: Excellent. Inspection welcome for serious buyers.
Reason for Selling: Not needed at the moment, snap them up before we think of something to put them on!
Item: Front pair BREMBO 4-spot brakes + 2nd hand pads, + slotted discs
Item Condition: Great
Extra Info: Came off a Honda DC5 Type-R Integra.
Looking a smidge under a grand for the brembo's... And about $1800 for the porsche...
brembos will fit under 17s and the porsche under 18s...
opinions?
They are:
opinions?
Yeah i saw them the other day as well, just a exxie for me at this stage (i know they are a bargin though). You have GPX ones at the moment dont you. I might consider buying yours off you if you do buy these, so that might help with the decision making
- FtoSam
- FtoSam
Yeah, the other problem I run into thou, is that when selecting a pad, I cant choose a high spec race pad like an EBC... I cant even heat them up on the track! I have to use a standard pad on the track - thats all good & well, they stop on a dime, but I use upto 50% of the pad after a days track use. So, Im stuck between a rock & a hard place, on the street the standard pads dont heat up enough & I have to use excessive force to pull the car up - and when you dont use the brake in 5 minutes, then temp drops to low again & you face the same issue. On the track they heat up perfectly & work like a charm - but I use over half the pad. If I went for a better pad, it would be even more useless on the street & still useless on the track! Yet I wouldnt wear half as much of it down...
So Its a fine line to tread, but I've decided on my 160kw track used car, 330mm is just too big. I reckon I'll gor a for a 300mm setup, with a mid range pad like EBC green. That size & pad combo I reckon would be perfect - yet untested.
Having said all that, I have heard rumors of a pad coming out from Japan, that is apparently just as good cold as is hot. Dont know if I can hold my breath for that long thou... adding pad replacement cost to my nos & tyre bill is really starting to make my track days very expensive!
- FtoSam
Just spoke to a performance shop near me...
Getting pics of the porsche brakes to send them...
They said the porsche brakes (6spots) are worth $3500 per caliper new...
so they said at $1800 they are an absolute steal..
they said they can also get pads that dont wear, yet heat up very fast...
i dont care about wear anyway... never even drive the bloody thing...
oh gawd, 353mm discs with a porsche caliper is going to look sexy as!!
- FtoSam
- FtoSam
hehehhee...
Sam... dont turbo your car... or at least budget a lot more....
hehehe that sounds familiar...
i really dont think these could be that bad... after all they are standard porsche brakes...
Rather than a set of Group A HSV racing brakes (pretty sure thats bens), these were initially built for a street car...
- FtoSam
Did you see my first post dickhead
- FtoSam
- FtoSam
they are from boost cruisin are they not.
- FtoSam
