Tightening handbrake cable
mr-charisma
Post by mr-charisma »
Probably a stupid question, but does anyone know how to tighten the handbrake cable? just want to check before I go messing around with it & stuffing soemthing up
BorepYano
Post by BorepYano »
there is a DIY for it... remember reading it but cant rememebr where now lol
um... tighten it from under the center console thingo (under where the 6 stacker would be)
mr-charisma
I'll see if i can post some pics to see if I need to tighten the bolt i'm thinking I need to..
FtoSam
Post by FtoSam »
take it to a brake shop for a check up... theres a chance one of the rear calipers is siezed... one of mine is... and thats the problem...
But could be just the cable... but i'd check the brake caliper first... (mine was passenger side)
pimped
Post by pimped »
Turn the nut under the cup holder to tighten and loosen the hand brake. See pic below:
FTOnick
Post by FTOnick »
is this very sensitive? how far do you need to wind the nut to get it much tighter? it won't snap if i do it too far will it?
mr-charisma
the one on the left hand side of the pic?
No you would have to do it insanely tight to break it, if thats even possible. Just tighten, check tighten check until you are happy
pimped
Post by pimped »
mr-charisma wrote:the one on the left hand side of the pic?
yep. that's it.
If you wind it up more than 10mm to get it tight, its probably time to think about replacing the cables. They do stretch over time & the FTO is notorious for having a really poor lever angle on the hand brake system. Even new, you need to wrench the handle up tight to stop it from rolling.
mr-charisma
If I have to replace the cables, please tell me I only need to replace the short section up to where it splits off into the two cables..
No you may need to replace the long ones. However my handbrake works awesome but yes they do stretch over time. But before you get too carried away whats the problem
Check your rear pads as well. If they are low, you'll loose tension as well.
FTOnick
Post by FTOnick »
I tried to tighten my handbrake but it is so hard to get something into the little hole. My thing seems to be as tight as i can get it but the handbrake is still so weak :? My brake pads are in good nick too.
FTOnick wrote:but it is so hard to get something into the little hole. My thing seems to be as tight
Yeah i suffer from the same problem :lol:
maggsy
Post by maggsy »
:slap:
eThix
Post by eThix »
Yeah i had to do this on my FTO, it was pretty easy work, you shouldn't have any troubles.
FTOnick
Post by FTOnick »
:moon:
But really.. i think i have got it as tight as it can go and its so weak :(
mr-charisma
Just take out the entire rear console, cupholder & all .. easy.
