rpw cams : any 1 got them in ther car?
- tintin
has any one got them in? what are your views on them ?
http://www.rpw.com.au/shop/index.php?op ... &Itemid=25
thanks
martin
thanks
martin
coilovers!! gaurenteed to make boobs bounce
- FtoSam
- tintin
did you fell the difrents with them from standerd? cos im keeping my engine na tuned so as an option was thinking i mite get a bit more from the engine?FtoSam wrote:They built my turbo engine... Got a set of 6a13tt Cams that they put in it..
As far as i know, you wont get much more out of the cams...
- FtoSam
- Mitsiman
Camshafts are usually the last thing you would do to an engine. Do all external items first like extractors, exhaust, intake manifold and throttle body upgrade, cold air intake and then piggy back computer with retuning.
If it is a manuel then a mildly improved camshaft grind naturally aspirated would work nicely. If its an auto I would not recomend it because you can run into issues of idle stability and I think this would just destroy a good car to start with. With the small 2.0 motor you have to be careful t not overcam the engine
Dude do you have extractors you should definitly get them for a cheap KW gaintintin wrote:did you fell the difrents with them from standerd? cos im keeping my engine na tuned so as an option was thinking i mite get a bit more from the engine?FtoSam wrote:They built my turbo engine... Got a set of 6a13tt Cams that they put in it..
- tintin
the bits ive got on/in the engine are
motec m800 ecu
heads skimed
ports polished
board out tb
rpw thermul gaskets tb and inlet maini fold
rpw headers/exstrators with there flexi pipe but was coustomised cos it hung down to low - ceramic coated with ful stainless system - exhaust wraped as well
induction pipe with hks powerflow greem mushroom but getting a bmc cda soon with my new air ram pipe
grtting a light weight fly wheel
and getting the 1.6 cyborg mivec gear box with lsd put on soon - its a manul
and light weight crank and alternator pull put on soon
thoses to be linked up to my induction to the right of the pic
motec m800 ecu
heads skimed
ports polished
board out tb
Tidy engine bay bro, looks good man well done.
- FtoSam
- tintin
- tintin
