Record last updated 05 / 02 / 2007
Country of origin Japan
Numbers built N/A
Year of introduction 2007
Engine
Engine 4B11 T/C Straight 4
Engine Location Front , transversely mounted
Configuration aluminum block and head
Displacement 1.998 liter / 121.9 cu in
Bore / Stroke 86.0 mm (3.4 in) / 86.0 mm (3.4 in)
Compression ratio 9.0:1
Valvetrain 4 valves / cylinder, DOHC
Fuel feed Fuel injection
Aspiration Turbo
Drivetrain
Chassis/body unitary steel
Front suspension McPherson struts, Eibach coil springs, Bilstein monotube dampers, anti-roll bar
Rear suspension Multi-link, forged aluminum control arms, Eibach coil springs, Bilstein shock absorbers
Steering rack-and-pinion, power assisted
Brakes Brembo vented discs, all-round, ABS
Gearbox 6 speed Automatic
Drive All wheel drive
Dimensions
Weight 1540 kilo / 3395.1 lbs
Length / Width / Height 4495 mm (177 in) / 1810 mm (71.3 in) / 1480 mm (58.3 in)
Wheelbase / Track (fr/r) 2650 mm (104.3 in) / 1545 mm (60.8 in) / 1545 mm (60.8 in)
Performance figures
Power 295 bhp / 220 KW @ 6500 rpm
Torque 407 Nm / 300 ft lbs @ 4400 rpm
BHP/Liter 148 bhp / liter
Power to weight ratio 0.19 bhp / kg
what do you guy's think about this car ?
Im totally in Love.
