4th gear
gecko
4th gear
Post by gecko »
just started doing it every now and then.. change into 4th let clutch out accelerate and pop out she comes into neutral...
~I feel lethal, on the verge of frenzy I think my mask of sanity is about to slip~
RallyMad
Post by RallyMad »
synchros on fourth stuffed? Or it sounds like an issue with the gear itself maybe.
Ecnerual
Re: 4th gear
Post by Ecnerual »
gecko wrote:just started doing it every now and then.. change into 4th let clutch out accelerate and pop out she comes into neutral...
gear box is fcuked! - the teeth on the 4th gear have worn away so it slips out everynow and then when its not fully in or you fast shift it
thats what happens when manual drivers like to fast cluth and dont have their stick all the way into there desired gear
im not sure if you can actually fix that unless u change the gear box altogether
my old 1990 celica had that problem it used to pop in and out
good luck finding a manual gear box for FTO
