Just after a pair of callipers from 256mm rotor setup. So if anyone has some left over from a 276 rotor GPX upgrade, I'd be happy to take them off your hands Location Sydney prefered
Is that CC Lancer GSR? If so I think they are the same if the disc is 256mm diameter. I'm not worried about PCD though cause all I need is the callipers.
Can you post a pic maybe?
Yeah sorry front callipers only. I don't need the GPX ones though. I need the smaller disc variety (suit 265mm rotor)
The CC GSR is the same I'm pretty sure. They use the same pads, spcs are the same. If you could post a pic that would be great. How much would you like for them?
