Leaking Water
an52ep
Leaking Water
Post by an52ep »
guys i have water leaking problem with my car.i found where exactly its leaking.sorry guys i dont know wats it called not even the micheanic knows .its behind thermoster pipeing .its 10 inch steel pipe.one of the pipe site in the engien block and other site in to jast under the radiator cap .if u guys can help me with the parts number and where can i get ? i call few places they told me they can import for me from japan but it will take 6 weeks if u guys have any spare of that .thanks
maggsy
Post by maggsy »
are you sure its a 10 "inch" steel pipe ;)
an52ep
Post by an52ep »
yes i m sure its matel pipe if u see u under the radiator cap u can see a pipe goes to engien block.i found the parts name form this site.its called water inlet pipe assom .if u chack out this site.if u go to Heating and Cooling section than water hose and water pipe section number 11 i m talking about sorry i couldnot eidt foto. http://www.completefto.com.au/CompleteFTO.asp?hid=164
Section 11
If you click on the pictures on that page it will take you to more detailed breakdowns and eventually a part number code that relates to the bit you are after. If you then enter the part number code into the find box and hit the search button, you should get the part number listed.
There is a chance ill have the pipe you are talking about, but I would need to be sure I had the right one. If you follow the steps listed above you should be able to give me the actual page the part is on though. Is it actually leaking from the pipe or where the pipe meets the engine/firewall.
    an52ep
    Post by an52ep »
    thanx dstocks i found the parts number. its called PIPE,WATER PUMP INLET(MD314546) if u have this parts let me know thanx
    khunjeng
    Post by khunjeng »
    lol 10"
    thats my size... :P
    khunjeng wrote:lol 10"
    thats my size... :P
    khunjeng
    Post by khunjeng »
    no need to be jealous :P :la:
