2 light issues
FTOnick
2 light issues
Post by FTOnick »
How do you adjust where the headlights are pointing? because mine are looking directly at the ground
and
Are the parkers meant to be on all the time while the engine is on (even when the lights are off)?
maggsy
Post by maggsy »
not sure how to adjust the headlights angle but i know for sure that the side lights are not meant to be one all the time.
u should definately get that fixed.
just take it to an auto electrician and they should be able to fix both problems.
No the parkers are not suppose to be on as mentioned above but pretty simple to change back to normal (if you know a little about elec) if not then take to get swapped around or just leave it. There is an adjustment screw and i thanks someone has posted about this before. Use the search button as see what you get, if no luck or someone else hasnt posted how to do then ill get some pics for you tomorrow night. to drunk to do it now 8O
FTOnick
Post by FTOnick »
yeah could you post some pictures please?
I8A4RE's DIY GUIDE: to adjusting headlight aim.
1)Park car about a 800mm away from wall.
2)Turn headlights onto low beam
3) Low beam lights should be not higher than the center of the headlamp on wall.
4) Adjust up and down by turning the adjustment screw (A)
5) Adjust Left and right by turning the adjustment screw (B) PICS WILL COME SHORTLY SO HOLD TIGHT
<a href="http://img526.imageshack.us/my.php?image=sasdlk0.jpg" target="_blank"><img src="http://img526.imageshack.us/img526/1188/sasdlk0.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us"></a>
BorepYano
Re: I8A4RE's DIY GUIDE: to adjusting headlight aim.
Post by BorepYano »
I8AFRE wrote:1)Park car about a 800cm away from wall.
FTOnick
Post by FTOnick »
thanks for the help, i found the screws
Re: 2 light issues
FTOnick wrote: Are the parkers meant to be on all the time while the engine is on (even when the lights are off)?
the parkers would only stay on while the engine is on if the car was serviced by a volvo mechanic :lol: but as above they are not meant to stay on.
THERE IS A SCREW WITH A P NEXT TO IT, DONT TOUCH THAT ONE
FTOnick
Post by FTOnick »
Oops... could you please post some pics actually then of the real screws
Is it bad if i moved the screw with the P next to it? should i change it back?
Its to do with the projecter and id say if you havent done any damage just leave it alone. im still tryin to add pic
FTOnick
Post by FTOnick »
Ok thanks
DaveO
Re: 2 light issues
Post by DaveO »
FTOnick wrote:How do you adjust where the headlights are pointing? because mine are looking directly at the ground
and
Isn't there a pushbutton just to the right of the main instrument cluster that turns the parkers off and on independant of the light switch?
DaveO
Grue
Post by Grue »
When you get the pics of the screws, and which way to turn them, think you could make it a DIY? Really can't find anything under various different searches.
TCGPX
Re: 2 light issues
Post by TCGPX »
and
DaveO
He he... Another burned out foggie switch :lol:
If your only getting parkers, dash lights and tail lights when that button is on, you have a typical FTO problem. The foglight switch has burned out.
Easy to fix... Wire in a relay like Mitsi should have done in the first place.
There are threads on this... Use the search button, then ask if you have any probs.
The switch can be disassembled pretty easily, mine had plastic melted all round the contact for the foggies, just scrape it away.
Still put the relay in there too though... Or else it'll just happen again.
[img]http://img259.imageshack.us/img259/1613/sigpic2se2.jpg[/img]
Yang i think u were trying to correct me (80 instead of 800) but no its 800mm or 0.8mtr
Ok for some reason image shack wont let me upload the image FTOnick add me on msn or pm me your email and ill email the pic unless some1 else can upload the pic for me
Grue
Post by Grue »
Last time I checked, 800cm was 8metres...
you've pm about pic
bahahah i meant 800 mm hahah sorry i got stop drinking
FTOnick
Post by FTOnick »
