I just had my GPX serviced and he rotated the wheels, its now got awful wheel wobble and was just confirming that all it needs is a balance / alignment. It had wheel wobble before (after an alignment & balance no less) so I'm open to other ideas as to what it might be.
Other thing as described is my passenger tail-lights brake globe has gone, how do I go about replacing this, I've never messed around in the boot before and can't find a guide on it anywhere, looks like it should be very straightforward but if someones done it before it would be a big help for any info.
You shouldn't need to pull the carpet up in the boot to get the rear lights out. Directly behind the rear lights in the boot are little flaps in the carpet that you unclip, exposing the 4 bolts for each light. Push the cluster out, might be a bit stiff if never moved before. Quick and easy job to change out a bulb.
