tiptonic help please please please
- mr_f700
just got in my car 2 go to the shop and my gearbox is having problems
its a 4sp tiptonic
the dash lights for the gearbox and not on at all and if u put it in drive there is no change when you stop and start again its like its starting on 4th or something
i tried turning the car off and back on again but to no avail
can someone please help me!!
thanx
its a 4sp tiptonic
thanx
What about when you put in to tip mode and take off, does it go through the gears normally or is it like drive, feels like it is taking off in 4th?
Check ECU codes
Check ECU codes
- mr_f700
Yeah sounds like its gone into limp mode.
Use the search. i think someone else has complained about this just recently
Yeah im looking now for you, when was the tranny oil and filter changed in it last?
Ok here we go i think this is the link but instead of watching the engine light watch N light
http://www.ftowa.com/html/workshop/workshopart07.html
Get the code number then some should be able to see what that means.
Probably input or output sensor
Nah dont get ahead of yourself. it may be something simple
look at my second post up. it goes into this mode cause it senors something wrong
- BorepYano
i'm assuming the instructions are on the link he posted up.mr_f700 wrote:sorry man that makes no sence to me at all
i cant watch the n light as none of the gears light up
follow the instructions and see what comes up. who knows the N light might come on just for this lol, no harm in trying
and as for you needing a new gearbox... maybe not, it could be something simple like previously said, sensors or something (i think thats ironic actually lol), or it might be the sensors actually did their job rather than just breaking and there is somethign else wrong, might just need to get parts of it fixed or replaced.
anyways... just try the error code thing. hopefully that will give us a clue as to whats wrong. that asided... where abouts are you? u might want to ask/search around for some good mechanics close to you.
