Indicator
harry90
Indicator
Post by harry90 »
my left indicator seems to be working perfectly... but when i use the right one... it clicks very fast.. anyone ever have this problem ? do you know how to fix it ?
Grue
Post by Grue »
Checked for a blown bulb?
kid_dynamite
Post by kid_dynamite »
Check that you have no blown light bulbs, and that the ones in there are of the correct rating.
One of those issues can alter the current draw through the circuit which causes the fast flashing. Other causes may be a bad ground, relay on it's way out, etc.
Yip 99% of time just a blown bulb. All manufacturers do this to let you know that it needs replacing
harry90
Post by harry90 »
how do i check for the blown bulb ?
HICAS
Post by HICAS »
harry90 wrote:how do i check for the blown bulb ?
turn your right indicator on and take a walk around your car, the blown one will be the one that doesn't flash, that is if it is a blown bulb.
No idea on how to change a bulb though, I haven't had that close a look at an FTO :lol:
harry90
Post by harry90 »
nah all the bulbs are working !!! any other ideas ?
kid_dynamite
Do you have LED bulbs in place of parkers, indicators or any of the other bulbs?
nicholas
Post by nicholas »
The cars have special circuitry that detects when the current is too high (I think its high, either high or low, it doesn't matter really) and it speeds up the flashing speed to draw your attention to it.
As stated, 9 times out of 10 it is because of a blown globe - take a walk around the car and check carefully.
If it is a blown globe, for the front lights there is an external screw (you need a screwdriver with a decent length to it) which you undo and then the light comes right out. For the rear lights, there are internal bolts that you need to undo - they're the ones underneath the flaps in the boot.
Either way, once you've pulled the light assembly out, look for the big circular plugs with wires coming out of them, twist them in the right direction and out comes the bulb. Screw in a new one and bob is your father's brother.
harry90
Post by harry90 »
thanks for the help everyone... i am taking my car for a service this friday so i will get the mechanic to check it up for me... most likely what everyone is suggesting.. but i am useless with these types of things.. so ill live with it for 2 days !!
ph3var
Post by ph3var »
Did you get this sorted out?
Because I have the exact same problem I can indicate left no problems at all but indicating right clicks really fast but the right side indicators dont flash at all.
Hazard lights and arming/ de arming alarm flashes all the indicators but when i try indicating right it doesnt work.
I have a feeling its the indicator stork but not sure.
Custom purple 1995 GPX manual
ph3var wrote:Did you get this sorted out?
yeah man id say tis the indicator switch in your case
