rev problem
nvdfto
rev problem
Post by nvdfto »
hi guys i notice my fto is reving at 1300rpm-1400rpm mark.
its a stock 95 gpx triptonic.
i wanna know how much rev is it meant to be.
on idle and when its in reverse or drive.
please help me out
JOeJOe
Post by JOeJOe »
On idle it should be around 500-750, when you put it into drive or reverse it should jump up a little but it wouldn't go over 1,000.
You can decrease the rev but turning this little thingy (my technical term) with a phillips head screwdriver, it's close to the tb.
nvdfto
Post by nvdfto »
mines the opposite on what u said man.
it idles on 1300-1400rpm. when i put it into gear it drops to 1000-900rpm.
i wanna noe how everyones fto idles n stuff on before i use the allen key thing n adjust it from the engine bay
maggsy
Post by maggsy »
As soon as i start my car the revs go to about 1300-1400, but then it slowly drops until it reaches about 700.
but my car is manual so it might be a bit different?
JOeJOe
Post by JOeJOe »
It also depends if the car is warm of cold, on cold idle its over 1,000 then slowly drops down as it gets warmer.
nvdfto
Post by nvdfto »
13000rpm-14000rpm is when it drops. i think im gonna ajust it later on tonight thanks a lot for the info guys. mayb i should stop fanging the sh*t out of it.
