DYNO
EURO
DYNO
Anyone here had their car dynoed???
where can you get it done in melbourne and for how much?
- GPXXX
- Blk-Jet
So if a car has never been dyno tuned for around 2 years and only mechanically looked after, there should be some problems arising that only the dyno can find. My car has also been taken through rouphly 10 breakdowns, simply due to me not filling the tank up. Does this harm the car in a big 'performance way'?
- GPXXX
what do u mean by filling the tanks up? as in fluids or in terms of petrol? if it's petrol, don't run empty too many times coz i've heard that you will have run into injector / fuel pump problems in the long run... as for engine oil, get the best you can lay your cash on - they are essentially your engine's blood.
you can swap oil filters, air filters, engine oil, spark plugs etc etc, but when u go through dyno runs they can find flat spots in the rpm curve to see where power is dropping and such... It's really more to do with fine tuning the ECU because from time to time, the computer will retard its ignition timing to compensate for discrepancies in fuel octane levels for example, or the cold-heat range of the spark plugs may not be appropriate for such a high-comp engine, nitty-gritty stuff like that...
in short, think of dyno tune as a way of extracting hidden horses within the current setup of your engine.
- GPXXX
not sure if the factory ECU can be reprogrammed like that, because it has an in-built feature which automatically retards the ignition timing by a few degrees whenever it detects a knock or pinging (and i'm sure we all know how and why that sort of sh*t starts so i won't go into detail about that)...
but yeah, get your injectors cleaned - who knows it might have some sludge stuffed on it from dodgy fuel...
- GPXXX
factory FTO ecus are not programmable in itself, however they can be reset (simply by disconnecting the battery). however you can run piggyback modules (ie: S-AFC) and tune them.
if you run an aftermarket computer, then you can tune them on the dyno to iron out any problems with lean mixtures or ignition timing etc etc
