Alternator Saga
- OzFTO
Alternator Saga
Does anyone know where I can get my (GPX) alternator tested in Melbourne???? I've had lotsa guys BS over the phone then not know what do do when I've shown them my alternator
Noone seems to be able to test it - they all say they can rebuild it then I have to re-install it and hope it works!! Any tips???
You can try a quick test at home simply by running the car and disconnecting the +tve from the battery. If the car still runs the alternator is probably ok. What sort of voltage does your voltmeter in the car indicate? What makes you suspect a dodgy alternator?
- OzFTO
The alt is definitely faulty - it's showing around 10-11v at the battery (idling without lights on). The battery also died fairly suddenly. I now have it out of the car - which took some doing
BTW if anyone wants tips on how to get the alt out of a GPX, I feel qualified in suggesting how to make it easier on yourself!
- OzFTO
It's definitley not the battery - I've had it tested by a mechanic (good friend of mine) and an auto elec and it's most likely the alternator. My concern is that noone in Australia seems to be able to do a full test on the alternator once it's out of the car (as mine is despite the pain in the butt it is
). Any auto elec can static test it and make sure the alternator is working but the complication with the FTO is that the ECU controls the output of the alt. Without a simulated ECU input the auto elec can't guarantee the alt is working (as opposed to a dodgy ECU) and can't guarantee that they won't damage it!!!!! Seeing as the alt is so hard to get in and out I want someone to test it properly (as per the service manual) before I "try it and see" in my car. I figure I'm spending so much time and money on my car - I'd like it done RIGHT the first time!
no luck with mi FTO at all these days...
my whole car turned off a few times today and i believe it is the alternator as the battery is newly replaced only a few weeks ago...
needed jump start like 4 times just 2 get back home
does anyone know how muchy 4 a new one or any place that can source and replace them in sydney?
- OzFTO
A friend of mine from REPCO said that they are now importing Champion brand alternators from O/S so they can get ones for the FTO. Call REPCO and quote the number on the alternator. I was quoted $650 for one for my GPX. If they don't have any luck, PM me and I'll put you onto my contact.
I'm still going to try to get mine rebuilt as it looks like a cheaper option - might take some time though....
- OzFTO
Seeing as a few guys need to change alternators, I'll let you know my method (with a qualified mechanic helping me out!!!) for my '95 GPX.
1. loosen off tensioning pulley and remove drive belt
2. remove the ball joint on the RHS suspension arm
3. remove exhaust manifold (at the bottom rear of engine)
4. jack up RHS of the engine (use a block of wood to spread the weight or you'll dent the oil (?) pan), remove the one engine mounting bolt and jack up a few inches, being careful of the aircon lines
5. remove alternator connectors and bolts and move it around (this is the hard part) until it comes out between the suspension arm and the engine - it's a tight fit!
The FTO manual states that you should unbolt the transmission and remove the engine - I prefer the method above!!!!
Needless to say - getting it done by your average workshop will cost you...
- OzFTO
Happily I finally found someone that could rebuild it for me - they did a pretty good job but charged more than they quoted so I won't recommend them. It wasn't until I had the work done that REPCO started importing new FTO alternators. Try them for your other parts like brake pads, etc - the prices are quite reasonable.
So - one more happy FTO (GPX!) owner bak on the road
