both are not working.
the 1st spun a crankshaft bearing.
and the second 1 a piston grabbed and has stuck.
i am stipping the 1st engine and will consider stripping the other, so if you need any engine parts let me know
just took the cams out also have a fuel rail, 2 intake manifols ect. even 2 mivec covers.
2 gpx engines
Sugar
- Ralph_Shang
- BorepYano
noisy tappets?Ralph_Shang wrote:can you fix a engine?
my car engine has lifter noise, can u fix it up with your engine part?
do a search on the forum for it, u should find lots of info and i think a DIY as well for it.
it's apparently a very common FTO problem
- nicholas
I was asking OverBoosting about a Ignition Failure Sensor, but he's taking a fair while to get back to me.
Can you confirm that the IFS was okay in either of the engines, and can I buy it
PS. If you don't know where to find it - it's got a 4 wire plug and is located behind the radiator filler cap (looking from the front of the engine).
