Stepper Motors for $90 on Ebay
umm
Post by umm »
Just Lettin everyone know that you can get new genuine mitsubishi stepper motors on ebay for $90 + $5 postage.
From http://stores.ebay.com.au/Cyberspace-Auto-Parts
The stores closed at the moment but. re-opens 19/8/07
They are the MD614368 MD628051 ones meant for 4cylinders. They don't say they'll fit an fto but i got one and it works.
I don't have any connection with them i just thought it was a really good price compared to gettin a new one from mitsubishi or a reconditioned or secondhand one fron NZ.
Female Turner On-erer
khunjeng
Post by khunjeng »
nice work mate!! $90 is a damn good price.
topao
Post by topao »
How much are they from Mitsi?
umm
Post by umm »
From my local mitsubishi dealer was $280.
devil2004
Post by devil2004 »
did you put it on a GPX?
umm
Post by umm »
Yep i have it on a gpx. I was pretty sure that GRs have the same one but don't quote me on that :wink:
khunjeng
Post by khunjeng »
its a great price...might snap one up when they are back online...
Blasphemy
Post by Blasphemy »
I bought one of these when mine died from the eBay guy. Bolted it on and it works a treat. Highly recommended. :D
mr-charisma
Post by mr-charisma »
Blasphemy wrote:I bought one of these when mine died from the eBay guy. Bolted it on and it works a treat. Highly recommended. :D
thanks for the feedback on that :)
RalliartBoy
Post by RalliartBoy »
Common problem with FTO's ?
Haven't had any problems with mine.
mr-charisma
RalliartBoy wrote:Common problem with FTO's ?
yeah its a fairly common problem, it was replaced on my car just before I bought it & I might need a new one again soon (after 2 years)
Sparhawk
Post by Sparhawk »
I replaced mine last year, with a stepper motor out of a magna (cant remember the model). The only a small differencewas the plastic plunger piece was a different length, so I swapped it from mine. Was the coils that were stuffed anyway. Has worked a treat since, and only cost me $50, but if you can get a straight swap NEW one for $90, I would...
[color=blue]Death is life's way of telling you - you're fired.[/color]
Oh Bugger, my sig block pic has dropped off the host ;(
RalliartBoy
How do you know when the stepper motor needs replacing ?
FTO338
Post by FTO338 »
RalliartBoy wrote:How do you know when the stepper motor needs replacing ?
This is why the search button is a good tool :wink:
http://www.ftoaustralia.com/modules.php ... pper+motor
Sparhawk wrote:I replaced mine last year, with a stepper motor out of a magna (cant remember the model). The only a small differencewas the plastic plunger piece was a different length, so I swapped it from mine. Was the coils that were stuffed anyway. Has worked a treat since, and only cost me $50, but if you can get a straight swap NEW one for $90, I would...
$50.00 brand new?
cb
Post by cb »
nice i like that :D
MuMan
Post by MuMan »
Is it the MD614368-MD628051
or..
the MD614380-MD628053 that interchange..seems to be some conflicting info on it.
Top one is 4cyl., other is 3.0 v6.
Anyone measured the coil resistance?
Original part number is E9T15296.
MuMan
Post by MuMan »
BTW in case anyone is interested or having issues..
When you do a re-set on the ECU it sets the stepper motor to default settings, so if you (someone) has played around with the air by-pass screw setting, then it may appear that the IACS is not working.
I do it this way...disconnect the IACS plug, warm the engine up & run it for at least 20 mins...adjust the idle speed to specs (~850) switch off & re-connect the plug to the IACS.
The IACS is there for enrichment only, not to continually adjust an out of adjustment idle setting..I think that's why they fail prematurely.
Albert
Post by Albert »
Visit
www.nardek.com.au
$125 gen Mitsubishi part
best thing is they know what fto is and its for 6 cylinder
the only thing is i put a new one and the idle is still low the guy told me to just slap it on and it should do it itself hmmmm?
any suggestions ?
I dont know a hell of a lot about these but have you reset the ECU?
