Identifying MIVEC to NON MIVEC
overboostin007
Post by overboostin007 »
I am just wondering if there is an easy way to tell the difference for mivec and non mivec engines, other then the plastic engine cover :) Are there certain things that you can pin point as to what is what?
overboostin007
Mivec
The only thing that i have noticed is the engine oil cap is located in a differrent position
mr-charisma
Post by mr-charisma »
If it still has the stock airbox, the GR will have a MAF Sensor unit attached to the stock airbox, a GPX will just have a pipe.
The oil cap is on the passenger side.
When driving the car you won't mistake the Mivec roar! Oh it is so sweet!
Not that you're going to check, but the alternators are different, GR is 2 pin, GPX is 4 Pin. ECU wiring is different for a few things, again, not likely to notice it.
Check the engine numbers, I believe DStocks has a listing on his site for deciphering the Chassis numbers
http://www.completefto.com.au/CompleteFTO.asp?aid=1
And (just to get a few of the GR members fired up) you would notice if you were driving a GR cause they're gutless as hell!
Grue
Post by Grue »
mr-charisma wrote:And (just to get a few of the GR members fired up) you would notice if you were driving a GR cause they're gutless as hell!
(Oh God, here we go again...)
That there's fightin talk!
Rocco
Post by Rocco »
The mivec engine has an inbuilt speaker that yells "yo" once u go passed 5500rpm
FTO-279
Grue
Post by Grue »
Bigger brakes on the GPX
overboostin007
fto
awesome. That's answer my question
