0-100 for tip??
- hnm738
0-100 for tip??
hi
i've got a gpx tip
got itg pod and i think 2.5inch exhaust
i time my self with a stop watch i keep on getting 10sec, 10.48, best one i got was 9.41????? from standing still to 100km
could any give me some advice or tell me what could possibly be wrong?
i can feel when the mivec kicks in in 1st how come the timing of 0-100 is so high?? or is that what a tip suppose to do?
and i also had a major service 2 months ago
thanks
i've got a gpx tip
thanks
- GPXXX
stock tip GPXs should manage mid 8s for the 0-100 quite easily, and perhaps slightly lower than that with the mods that you have mentioned.
if you're getting 0-100 dashes in the 10s, then either:
1. your timing is inconsistent
2. engine is not well tuned (poor fuel/engine oil/ engine or gearbox condition etc)
3. you're not feeding enough revs when launching
4. inconsistent road conditions (were you timing yourself when driving slightly uphill or....??)
5. You're not shifting at optimum rpms
Just a few factors off the top of my head...
- FTO338
Sorry to say this, but those things u quoted won't help u much on 0-100, & the time is about rite, if u doing stop start 0-100 without "rev-launch"hnm738 wrote:hi there
i have optimax
got f1 tires
and everytime i accelerate i press the pedal down as far as it can go
got mobile super synthetic oils 5-50w
when you say tuning? how can i do that now?
- hnm738
but isnt stock specs were 7.8-8.5secs??? and thats without anymods??
but if what you said was true what can i do to the car?
headers for $1000
that exhaust mod that smorison is doing for $550
throttle body $600
computer $1000
hi flow cat $250
flywheel $600
which is better and more worth while doing than the other
also does anyone know about close gear transmission thing?
just wandering bout that becuase in the games it sure help the car go a lot faster
headers for $1000
throttle body $600
computer $1000
hi flow cat $250
flywheel $600
- GPXXX
firstly, u need a direction and more importantly - a budget.
You can only go as quick as your budget allows, and it also depends on what you're aiming for (circuit racing, straightline speed, high-speed runs)
and having said that I wouldn't bother opting for a close-ratio gearset for the FTO tiptronic, even if you've got some significant mumbo under that hood. Instead i'd rather spend the money on rebuilding the gearbox with stronger internals and torque convertor plus a higher stall for a better launch... either that or go for a manual conversion, but don't waste your time with custom close-ratio gearsets on a stock tip 'box.
...oh and by the way, a game is a game - don't be fooled by its realism and apply them in the real world hehehe..
as for the mods you have mentioned above, well again it depends on how much you wanna spend. my 1st preference would prob be the headers and Steve's exhaust mod, but that's just me...
If you want to stick with a tiptronic, but want a closer ratio gearbox, then buy a 97+ model which has a 5 speed box, rather than the 4 speed box of the earlier models. Each of the gear ratios will be shorter and will get the car into the Mivec range / powerband faster. Don't expect it to shave much time off though!
- GPXXX
well going by the 1st sentence alone sounds like you want more torque down low, in which case I'd recommend an extractor instead. fitting a lightened flywheel will only give you negligable increase in accelleration and it does have its trade-offs too (particularly when driving uphill)hnm738 wrote:what i just want is when i step on the pedal at any speed it picks up speed faster
would hte flywheel make it go faster? well i duno what budget i would have now just getting ideas from you guys and decide from there
- GPXXX
well after being taken for a ride in Eric's (MADFTO) car, I can tell you the extractors that he has fitted made quite a difference on the road, and i assure you it has nothing to do with the aural sensation from his HKS exhaust haha...
however it was fitted to a manual FTO, hence i'm not sure if the extractors will give you a world of difference for a tiptronic 'box because the torque convertor would've absorbed prob up to half of its gains (if not more) anyway... (no disrespect to 'tip owners out there)
- hnm738
yes its comming from the pod
but it sounds a lot louder than any other cars
is it because the air screw is too open? the noise is loud and can also hear noise like bells ringing inside it its really weird
theres a screw at the top on the other end of the pod pipe
when i adjust that the pod goes softer and louder so as my idle
so should i adjust it loud or soft
i first few things that come to my mind, is that your cars wheel might not have enough grip, u could be having wheelspin coz u floor it (i get wheel spin if i floor it from stationary)... and using stop watches are inaccurate anyway... your car could also be heavier, and also u said u have your aircon on when u drive, well thats another factor coz the aircon takes some of the power (shares power)..
if u redline it every gear to 100km?? u'll only be up to 2nd gear?
if u want it go faster
get NOS or fuel additives
i think kevin knows what im talking about? the one my frnd put in his golf?
- GPXXX
kirby, i think your tyres are not up to scratch - it shouldn't be that easy to light up the fronts unless it's very wet because the FTO does not really have a heap of torque down low anyway (unless u meant a brief tyre-chirp off the line)....thecook wrote:...is that your cars wheel might not have enough grip, u could be having wheelspin coz u floor it (i get wheel spin if i floor it from stationary)...
- FTO338
It also depends on your tyres' pressure, those who been 2 tracks before would agree with me even 1psi would make an effect in grip & cornering.GPXXX wrote:kirby, i think your tyres are not up to scratch - it shouldn't be that easy to light up the fronts unless it's very wet because the FTO does not really have a heap of torque down low anyway (unless u meant a brief tyre-chirp off the line)....thecook wrote:...is that your cars wheel might not have enough grip, u could be having wheelspin coz u floor it (i get wheel spin if i floor it from stationary)...
