headlights
headlights
hey all,
My left headlight is delaminating, the thin plastic coating seems to be chipping away...
Is there any fix for this? or do i need to get a new headlight?
jono
ps has anyone had this problem?
jono
- airbornespanner
- airbornespanner
demonjay, yes that can be done it is a time consuming job if you can get a micromesh kit, it is a matter of using a stage of fine "sandpaper" starting with a coarse grade finishing with an ultra fine, but you have to know what you are doing, we use this type of system on aircaft windows but we leave it up to the professionals. I had my headlight done by ASP 2/6 Tennyson street Granville NSW Ph 02 96376455. As I mentioned before check with any plastics fabricators in you area I am sure that the can help you or let you know who to see. Any more help just let me know.
- airbornespanner
- smorison
- The Godfather
umm... i wouldn't want to use wet n dry on perspex you just won't get it clear enough unless you are a professional. you could try a rubbing compound and high speed buffing but again you'd have to be very careful that you don't over heat it.demonjay wrote:Apparently you can sand it out with a bit of wet and dry...havent tried it out, but if someones done it, please tell us how
best to get it done professionally as a replacement (used) headlight will set you back around 400-450
I happened to mention this problem to a guy in a bodyshop over here in the UK and he took his 'sander' to it - used the finest grade wet & dry he had and basically rubbed away the peeling lacquer, then polished it up afterwards - 5 minute job, lights look like new!
Hope that helps.
Hope that helps.
<P>Hostile Smoker<BR>14.92 sec 1/4 mile<BR>[img]http://www.hostilesmoker.pwp.blueyonder.co.uk/FTOSite/pics/strip.JPG[/img]</P>
- airbornespanner
- airbornespanner
