hey
does anyone know where i can get an intake manifold gasket from? im gonna change my sparkies and ignition leads ...
thanks
chiangstar@yahoo.com
Gasket
Hi mate, you shouldnt need a need gasket if you are in any way careful about what you do.These things are quite tough and can be re-used.I have had my inlet manifold off several times and never needed to replace a gasket yet.Camskill down in England have never sold any of these either because most people just use the original one...Hope this helps.
- smorison
- The Godfather
You could probably get the gasket from any parts suplier ie: autobarn, etc as the late v6 galant has the same engine (except mivec) as the fto. If your in a hurry buy a galant gasket from mitsubishi, they should have them in stock as the 2.0 v6 galant was released here.
