Air con pipes
Private Sales Only
msbchi
Air con pipes
Post by msbchi »
Does any one have the pipes that run from the gas bottle ( the ones that carry the gas) I just put a hole in mine while changing the battery, shorted out with the spanner and in a split second caused a pin prick hole for all the gas to escape from. You know the one just beside the inspection window Also looking for the seat rail covers and the plug that covers the seat belt guide HOPEFULLY BEFORE AUTOSALON
The lot
Think I have all those bits. If you could describe exactly which ones/how many, that would be good. Not sure which AC line you are talking about - will go and have a look at car now and try and work out which one you are after.
PM Sent
cheers
